Results 1 to 6 of 6
Thread: 350x big bore to 452 carb question
    joe_f7's Avatar
    joe_f7 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2008
    SE wisconsin
    227
    what is the best carb and jetting to use with the 452 big bore? i have the bigger valves and ported head. i do want to retain the stock air box. what the best way to do this? someone on here suggested a 38mm PE keihin, but just wondering what you guys have been using. any other pionters on the motor would be appreciated.
    1986 Kawasaki KXT 250 tecate
    ported, FMF pipe, DG silencer, boysen stage II reeds, 39mm keihin PWK, T4 thumb throttle and front master
    PA
    3,515
    thats what me and my buddys run on our stock to 460cc motors....great carb!
    you can still get it in kit form for a 250x but i have found out that a warrior 38mm PE comes jetted closer and the large side of the cab is turned down alittle so i think this would help fit the stock air tube.
    WWW.HREATV.COM
    joe_f7's Avatar
    Mar 2008
    SE wisconsin
    227
    what do you guys run for the airbox? or do you put a open element on it? also are you talking about a yamaha warrior?
    PA
    3,515
    the bikes with that carb have from stock box with no lid to full custom aluminum boxs. all are using K&N filters.
    yup a yamaha warrior 38mm PE carb kit
    WWW.HREATV.COM
    joe_f7's Avatar
    Mar 2008
    SE wisconsin
    227
    was also thinking a 38 or 39 FCR carb.
    PA
    3,515
    if this is on a trike that might be a tight fit
    WWW.HREATV.COM
