Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Thread: Help Me Get This Thing Started
    BAM is offline New to the board Arm chair racerNew to the board
    Mar 2009
    Roseville Michigan
    I have a 85 yamaha 225dx. I found this in front of a house getting ready to be thrown out. As the people were dragging it out i started to talk to them. They said it had been sitting there for about 15 years. So far i have replaced the spark plug and the battery. The engine does turn but it does not start. Also i do not have a key for it because the recent owners must have ripped out where you put the key in. I would like some help on how to get this thing started and running.
    Mar 2008
    Wichita, kansas
    123
    Just go thru the motions. Clean the tank, Clean the carb,new oil make sure it has compression and spark clean the air filter
    My Rides
    1985 350x- Super Trapp Exhaust
    1984 YTM 200
    2005 Trx 450r
    Feb 2009
    Wisconsin
    521
    Are you using the pullstart while your trying to start it? My yama starts faster with the pullstart then the electric start.
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    pudge is offline At The Back Of The Pack Arm chair racerFirst time rider
    CT
    159
    you say there is no key? you sill needs to mess with the wiring bye the key, it will turn over all day but not start until you by-pass the key
    Hampton, Virginia, C.S.A.
    2,664
    Quote Originally Posted by pudge View Post
    yup check to see if your getting fire...im willing to bet you arent...if you arent ticker ith the wiring and see if you can find out how to complete the circuit...and i bet she will run
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Mar 2009
    Buffalo New York
    54
    Since it's been sitting forever I would :
    Change the oil .
    Drain the old gas .
    Clean the air filter .
    Clean the carb .
    Put a new plug .
    Make sure the ignition is on...get a wiring diagram to by-pass .
    Then make sure you have spark...fuel and compression .
    Before you no it she'll be running
    Aug 2004
    Nampa, Idaho
    1,245
    Post some pictures. We'd like to see how it looks.
    Current rides
    83 185s
    06 Rancher ES
    95 Ford F150 4X4
    2000 Ford Explorer Sport
    Apr 2004
    Brigham, Québec, Canada
    1,528
    I think all you need to do to bypass the key switch is unplug it. Also probably a key from a Yamaga ATV of this era should work.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    CT
    159
    Quote Originally Posted by Yamada View Post
    good point that should work, just pull the connectors off the back of the ignition....if that dont work touch the connectors together and try that
    louisiana
    1,499
    heres u a wiring diagram,hope that helps a little.http://www.files.3wheelerworld.com/W...5DXKDXLDXN.jpg
    Signature pic removed,becuase of no helmet.
    It's almost always the carb thats all gummed up on trikes that have sat for long periods of time.....
    Check for mice in the airbox before you pull that cord one time!! (too late)
    Mar 2009
    Roseville Michigan
    Quote Originally Posted by threewheelin-feelin View Post
    How do i check to see if im getting fire?
    Mar 2009
    Roseville Michigan
    Quote Originally Posted by 82cutty View Post
    Change the oil .
    Drain the old gas .
    Clean the carb .
    Put a new plug .
    How do i check for compression?
    Mar 2008
    Wichita, kansas
    123
    take the plug out but leave it on the coil wire and ground it to the motor and watch it as you turn it over you will see spark...be carefull it will jump out and bit you if your not...
    My Rides
    1984 YTM 200
    2005 Trx 450r
    Mar 2009
    Roseville Michigan
    Im only 15 and I dont know a lot about these machines so anything you can post to help me out with it I would really appreciate it
