1985 Auto X lots of upgrades
1982 Honda 185s 3inch wheel spacers, bassani exhaust
2001 400ex
1983 110
yes they are. the 4 exposed nuts hold the rim assembly to the hub, and the other 4 hold the halves together.
current rides:
05' 400ex
02' yz85
84' 200es big red
84' 200s with tlr200 engine project (almost done)
84' atc 110
83' 225dx with 340cc kohler sled engine
ok thanks, any tips when changing tires out?
2001 400ex
1983 110
Sometimes they can be tough getting them to seal when using tubeless tires. Make sure you clean them real good before you mount new tires on them.
Current rides
83 185s
06 Rancher ES
95 Ford F150 4X4
2000 Ford Explorer Sport
i used carpenters glue on the rubber orings to hold them down and they sealed very well![]()
Well started at 5 and had a dinner break in there. Took me 2 1/2 hours to fully demount and clean the rims with a wire wheel. I had one rim done in like 10min but the second one was rusted on the inside and took a while to get off.
New tires hopefully coming tommrow!
2001 400ex
1983 110
haha, typical, took me that long too, but I used silicone to hold the o-ring and as a sealer as well. My old tires where so bad, I had to cut them off.
But they worked out great!, I actually prefere the split over the one peice, but they don't look as cool
