Thread: 86z inspecting the damage
    Oct 2007
    Barnesville Ohio
    239
    i finally took apart my 86z to put a 5speed in it i found out that 3rd wasnt working because on the back of the gear where the 3 prongs match up with the other one it has rounded both the prongs and the mating part of the other gear so i can get them cut some of the others are starting to round but i will get it fixed sumtime anyone on here grind these or know of anyone good with reasonable prices to do it?
    im at a hult with it now because the special washer on the back of the 85 input shaft is diff than the 86 and i had to order one but this thing is still on stock bore and crank/rod with great compression so thats always a +
    TRIKES
    1983 225 DX
    1984 Tri-Zinger
    1984 200 X
    1985 Big Red
    1985 200 X
    1985 Tri-Z
    1985.5 Tri-Z
    1986 Tri-Z
    BIKES
    1978 YZ250
    2010 YZ250F
    2015 WR450F OHIO Street Legal
    Sep 2006
    Northwest Indiana
    1,893
    It will require a professional shop that specializes is cut trannys. I have used MRE in Florida. Both sets of gears will have to be sent. And be sure to inspect fork pads, and drum. They take a beating when popping in and out of gear. 6 speed forks can be tough to locate too.. The 'prongs' are referred to as dogs btw.
    Oct 2007
    Barnesville Ohio
    239
    the 2 for the output have wear and i can feel the diff with my finger could it be welded and grinded down again or will it make the arm to fragile
    cam is perfect
    TRIKES
    1983 225 DX
    1984 Tri-Zinger
    1984 200 X
    1985 Big Red
    1985 200 X
    1985 Tri-Z
    1985.5 Tri-Z
    1986 Tri-Z
    BIKES
    1978 YZ250
    2010 YZ250F
    Apr 2006
    Crestview, Florida
    2,429
    why dont you just put a add in the classifieds on here for the gears you need to fix the 6 speed gear set?
    Rides
    85 ATC350X
    85 ATC200X
    this guy can fix your tranny
    http://w-c-r.com/
