Results 1 to 3 of 3
Thread: Cig Lighter
    Mar 2009
    Bellevue, WA
    54
    Cig Lighter
    Is there a mod to put a cigarette lighter on my 200x? I figure ill prob. need a better stator too. I want one to power my cell/gps when I go camping with this guy later this spring/summer.
    Anyone done this yet? Is there a kit?
    braunz200x's Avatar
    braunz200x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Toronto
    158
    you ahould be able hardwire a 12v access outler to any wire that is always hot in the headlight bucket
    as far as putting to much load on the stator i wouldnt know im sure someone on here must have experience with this on their atv or motorcycle
    May 2008
    Northwestern Ontario, Canada
    552
    You can do it, but it should be run off a battery, like on a Big Red or similar type bike with a starter battery. The problem with stator power is that it's not "clean" and won't run stuff very well. Best bet is to just run it to charge the batteries on your gear when your zipping around...at idle it won't do much at all.
    I'd probably look into a cheap solar power charger that will run small stuff like a GPS really easy. It will even charge your car battery by plugging it into the lighter to boot!!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
