Results 1 to 14 of 14
Thread: blowing smoke out the carb?
    acidburn is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Cornwall
    344
    my bike wont start it wouldnt do anything untill i moved the pulse generator now its "trying" to start it spits sputters "barks" but it wont start! it just blows smoke out the carb(i took the aiirbox off)
    Mar 2009
    Alabama
    4
    sounds like bad muffler bearing or maybe it need a can of compression
    Dec 2005
    Wisconsin
    1,141
    Piston rebound spring???
    Did you have the cam out or the pulse generator off the cam? By chance do you not have it firing on the right stroke?
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Cornwall
    344
    its fireing on the rite stroke. i dont know what it can be :S
    Mar 2009
    florida
    6
    if it wont fire and run for a few seconds on starting fluid then its screwd up pretty good,take a compresion test like they said.and put everything back the way its suposed to be.
    if you got a good strong spark and a new plug and it wont run on starting fluid the thing is tired.
    Miami,Fla.(305)
    808
    sounds like timing is off. be sure to double check your timing marks again. sounds like your timing is off. might have sheared the woodruff key that holds flywheel.
    Mar 2007
    Texas
    5,045
    Quote Originally Posted by charles_ma View Post
    if you don't have anything decent to add, don;t post. this is junk we don't need....
    ________________
    https://www.mikesatvfix.com
    Oct 2007
    Grosse Tete, LA
    3,440
    well vote it down oscar...I know I did...and voted yourself up.
    Mobile, AL
    74
    lmao. . . muffler bearing? can of compression?
    that cracks me up
    Sep 2007
    Hawley MN
    144
    sounds too me like a broken powerband... but thats me ahah jk
    Yeah sounds like timing is off, check the marks on the fly wheel, check to see if the key is sheared. Also wouldnt hurt to check the cam timing.
    Trikes
    86 250R
    82 ATC70!
    Previous Trikes
    85 TRI Z
    86 200X
    87 200X
    Cornwall
    344
    :S it recently had a new timing chain installed so i wouldnt think the timing would be off but i guess ill check tomorrow.
    and also when i took my carb apart i had no clue to what i was doing all my buddy told me was to split it open twist both flat nead nosels off and stick a needle through then i just tightened both flat heads as tight as they go..
    Mar 2007
    Howard Beach, New York, United States
    687
    i am getting smoke out the carb ocasionally as well, the bike will run and rev, but not well anything past idle is rough and hesitant if held, it will get a surge of power, but only for an instant. how can you tell if the key is sheered? i have tried jetting all the way lean and all the way rich and the symptoms are the same. this is a fresh top end. how exactly is the timing done, from what i did i made sure the arrow on the cam was center in the view port at the same time that the first 'o' mark is lined with the index. which i know know is wrong, so is it supposed to be the 't' mark or 'f' mark?
    Current Project:1978 Pontiac Phoenix 355 v8
    Past Bikes: 1999 Yamaha Big bear 350, 1981 Yamaha XS 400, 1996 Yamaha yz250 1984 Honda big red, 2004 Xtreme cr107, 1999 Yamaha bear tracker, 1999 Suzuki ds80 STOLEN, 2005 Kawasaki klx110, 1986 Honda trx200sx
    Daily Driver: 1990 Buick Electra Park Avenue 3.8 v6
    Apr 2006
    Crestview, Florida
    2,429
    Quote Originally Posted by honda_atc200es View Post
    T mark, also you need to set the valve clearance
    Rides
    85 ATC350X
    85 ATC200X
    Oct 2007
    Minneapolis mn
    4,067
    Set the carb back to where it is suppose to be. When you are trying to diagnose a problem, only change 1 thing at a time. Sounds to me like your carb is in need of adjustment, and your timing is off. Who replaced your timing chain?
