Results 1 to 7 of 7
Thread: Problems With My Rear Brakes
    Feb 2009
    Listowel, Ontario
    18
    ok heres the deal i drive a honda 250r and this winter i took it out and my brakes ceased now ive taken them apart and everything is loose now i also took apart the the foot brake thing that pumps the oil in the line now heres the problem i put everything back together and re-attached it to my ATC and it doesn't work the oil isnt going back through the line its just going in and out of the foot pump WHAT IS WRONG!!!!! please help
    Jul 2006
    Huntington, Indiana
    28
    I hope you mean brake fluid not oil! If you took the brake lines off you will need to bleed the air out, just like is done on cars or trucks.
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Be sure your useing Dot-3 or 4 fluid. Fill the reservior, pump the pedel several times, then crack the bleeder. Do this repeatedly until just fluid comes out, no air.Good luck.
    TF 07,08,09,10,11,12,13,14!
    Feb 2009
    Listowel, Ontario
    18
    yes i ment fluid
    Carrollton Texas
    76
    i had 3 trikes with the same issue , i had to get a manual vaccum pump because the brake fliuid does not flow as it does on the front , not enough gravity i guess.. anyhoo, the other way i was able to get fluid in the caliper and the air out was to do the same style of bleedint the brakes like you do a car , i would pump it a few times, hold it in, put my finger on the bleeder hole (or tighten the bleeder bolt) , release the brake pedal and wait a few seconds for the master to suck in some fluid and repeat this procedure a few times till i get the results i want.. worked for me , but after a while i decided to get a vaccup pump to make it easier ( i am lazy)
    because 3 wheels are better than 4
    jadleybray's Avatar
    jadleybray is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    oregon
    352
    It can take a long time on stubborn brakes pumpin the pedal. The vaccum pump is the way to go forsure, and a cheap one works fine.
    Feb 2009
    Listowel, Ontario
    18
    thanks guys its got fluidn in the line now.......... now all i have to do is get a new seal its leakingin the piston now thanks for your help
