Results 1 to 3 of 3
Thread: 85 250r....I have oil/gas in by the flywheel..
    boosted96cobra's Avatar
    boosted96cobra is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    n utah
    279
    O.k. So I pulled off my flywheel cover and it had a little oil in the bottom of it. So I reached and felt the bottom, had a bit of oil in there. Smelled it...smeels like gas also. So is my crank seal leaking? The bike idles great, but was really hard to get jetted correctly and sometimes when I start it I get a bad backfire....would this explain both?
    http://i291.photobucket.com/albums/ll292/sagep11/IMAG0069-1.jpg
    84 tri-zinger
    85 ATC 250r
    86 TRX 250r
    85 ATC 350x
    86 ATC 200x
    Does the crank wiggle up and down just a hair also? You really have to grip it firm and it may have just a tiny bit, but usually the seals and bearings are 25 yrs old and should be done.....
    You can also do a "leak down test" but being as to the design of a seal, I feel that forcing air through a seal from the crank helps it seal and may not always show a leak.
    Most times you just have to say to yourself (honestly) how many hours are on this bottom end......
    I try to do 1 lower end for every 2 or 3 top ends
    Apr 2008
    NW, IND.
    842
    +1 leak down and yes it sounds like the seal.Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
