Thread: 1984 70 atc won't start
    Mar 2009
    sparks/nevada
    9
    I have a 1984 honda atc70. was under power and died. It acted as if the kill switch was turned. Put new plug in and plug wire. Not sure on what else to change or if there is a way to check with volt meter. Any help would be great.
    OHIO
    2,857
    Is there spark?? Sounds like points are smoked or out of time?? Check for spark. If there is none, replace and regap points on stator plate. Be sure you check your plug wire from coil as well. Cut new end and retwist coil cap just to make sure. You can check continuity with a tester from engine to plug as well. Hope this helps.
    pa
    137
    yes do what crazy said and you should be back in biz! let us know how you make out.
    UlsterATCFan's Avatar
    UlsterATCFan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    UK
    363
    Make sure theres plenty of clean gas in the tank and its getting to the carb
    Dec 2002
    Spruce Pine, Alabama
    1,263
    My boy's '84 ATC70 did the same thing. $24 for a set of points and a condenser, an hour of work, and it started on the first pull.
    '84 ATC70.....my 8-y.o. son's ride
    Sep 2007
    oregon
    2,292
    also sounds like the carb...
