Results 1 to 15 of 15
Thread: Auto X
    Feb 2003
    100
    Auto X
    Hey guys, I am kickin around the idea of turning a 1984 200X into an auto X aka 200X with 185/200S engine. I know it has been done quite a few times. If anyone has details to share, articles, pictures, hyperlink that shows how the steps, etc I would appreciate it. I guess I should check the classifieds if anyone is interested in trading a 185/200 engine for my 200X engine. Thanks!
    gizmo_22's Avatar
    gizmo_22 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2006
    Bathurst NB Canada
    305
    I just did that not too long ago, engine is a bolt in, but you need the 200x rubber intake manifold from the engine. Other then that fab a brake pedal and your good to go... Ill find my thread on it and post a link
    edit here ya go http://www.3wheelerworldforums.com/s...ad.php?t=86105
    Aug 2006
    Arlington, Wa
    1,027
    I did one for my son with a 185 engine. The brake setup took the most effort. Find you a 350X brake pedal, and slip that over the footpeg mount. (get smaller seals for it first and tap it for a zerk fitting) I then went to NAPA and got some throttle linkage for a heavy truck with some all thread and jam nuts. Presto.... easy cheap brake pedal installation. You will need to bend it a bit because the clutch cover on the auto bike is much wider. I'll post a link to my thread for you.
    Bill
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    85' YTM 225DX (sweetie)
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Aug 2006
    Arlington, Wa
    1,027
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Feb 2003
    100
    Thanks a lot guys for the info. Looks to be pretty straightforward swap with minimal modifications. Just gotta find the time lol.
    KILLER's Avatar
    KILLER is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    oriskany,n.y.
    284
    there are a fun and cool bike to start on . i put one togather for my son a few years ago .he now has a 250r .so the auto x is on e-bay now . ends today .
    Feb 2009
    Rome,NY
    1,046
    Easy swap. I used the 185 harness so I need to put a x plug on to run the headlight and I used the 185 pedal (custom freak pedal) for the breaks and everything works good .... except the motor smokes alot so I got a 200 cylinder boared 50 for it.
    rugabugadouglas's Avatar
    rugabugadouglas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    iowa
    269
    what do they go for on ebay my brother in law is hurting for money and wants me to sell his auto x
    Aug 2006
    Arlington, Wa
    1,027
    Quote Originally Posted by rugabugadouglas View Post
    unfortunatley 4 - 500.00 I'd tell him to keep it and donate some of his "fluids"
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    CENTRAL NY
    1,709
    They are a very cool bike and a ton of fun.. Very easy swap too.. I helped with Killer's and autoXer's builds.. The brake lever is the biggest hump to clear.. So far we've found the 185/200 lever to be the best.. Just drill it bigger to fit the foot peg post, and bend it alittle to come out from the motor, we also had to grind it alittle where the linkage goes on it.. The sprocket cover also has to be cut down to clear the frame but its not a big deal... Also some times the left foot peg has to be spaced out like 1/4 of an inch to clear the shifter shaft.. On my brothers we had to but on autoxers we didnt? Not to sure way on that?
    Something id realy like to see on an autoX is bar mounted rear hydrolic brakes.. Get a master off of a sled or a newer 4by4 that has a left side master and run a braided line back to the caliper.. I think it would be trick to have both brakes on the bars...
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    Aug 2006
    Arlington, Wa
    1,027
    Quote Originally Posted by freaksfix View Post
    That is a darned good idea!
    Charlie Don't Trike
    85' ATC 350X
    85' ATC 250SX
    84' ATC 200 auto X
    85' ATC 70
    85' YT 60
    My Partz Auctions
    Apr 2006
    Crestview, Florida
    2,429
    Whats wrong with your X motor?
    Rides
    85 ATC350X
    85 ATC200X
    Feb 2003
    100
    I have the X motor out and is a complete running engine. Exhaust studs are busted off. I have a brand new clutch for it too. I am actually gonna use this bike for towing my acreage mower and the automatic to me is a little easier to work with.
    Mar 2007
    Howard Beach, New York, United States
    687
    I have an engine!, needs to be put back together though
    Current Project:1978 Pontiac Phoenix 355 v8
    Past Bikes: 1999 Yamaha Big bear 350, 1981 Yamaha XS 400, 1996 Yamaha yz250 1984 Honda big red, 2004 Xtreme cr107, 1999 Yamaha bear tracker, 1999 Suzuki ds80 STOLEN, 2005 Kawasaki klx110, 1986 Honda trx200sx
    Daily Driver: 1990 Buick Electra Park Avenue 3.8 v6
    Feb 2003
    100
    Thanks, but I was hoping for a drop in and go engine.
