i am trying to check to see if my pulse generator for my 85 350x is good or bad , and the more i check it with my ohm reader the more confused i get.
i believe spec is like 297-363 for resistance on it.
if i check the resistance with my ohm meter on 200K the reading is .2
if i check it on 20K the reading is .33
if i check it on 2K the reading is .345
and if i check it on 200 the reading is intermittent , 191 one time 55 the next 85 the next time , i dunno what the hell i am doing here .
I am not a damn electrican this is all new to me , i just don't understand why on 200k , 20k , 2k it will give me a reading and the reading will stay on the screen till i pull out the 2 pins , but on the 200 setting it will give me a reading and then go blank , and then i have to pull them out and stick them back in and it will give me a totall different reading for a second. Anyone understand this and know what reading i use to determine if i am out of spec or not ?![]()
cheers to you
