Results 1 to 7 of 7
Thread: Types Of Tools Needed
    Aug 2007
    Alberta
    45
    So I was thinking ya know I would like to rebuild by 200M from top to bottom due to the fact it does not run ever since I laid it on its side.
    Istead of paying $500 candain for a rebuild I want to rebuild the engine myself.
    So people what tools would be needed to rebuild My 84 ATC 200M or any other trike.
    I am sick of people always telling me you need special tools so i desided to get myself the tools needed.
    Thanks
    200M's
    Oct 2007
    Anna, Tx
    165
    for the most part, a good set of wrenches, sockets, and allen wrenches will get you started. a flywheel puller for your engine will be useful, and of course the factory manual, which you can download, just do a search.
    85 200x
    84 200x-autox
    84 200s--parted out
    85 70
    85 70
    84 70
    69 QA50
    70 trail70
    81 yz250
    82 yz80
    Lancaster, PA
    1,738
    there is a 4 prong clutch tool that you will need
    ebay
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Aug 2007
    Alberta
    45
    lol you got to be kidding me wow thats all you need? I have most of these stuff all ready.
    Thanks Guys!
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    flywheel puller
    rubber mallet
    copper/plastic
    gaskets
    8mm,10mm,12mm,18mm,14mm
    torque wrench
    impact wrench
    carb cleaner
    new seals/bearings
    thats for a 2 stroke...
    Nothing to ride... for now
    Sep 2008
    845 New York
    2,302
    screwdrives and somesort of picks and wire brush to clean crap up
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    louisiana
    1,499
    this will get the motor out of the frame...front motor mounts 12 mm,14mm,top motor mount 12mm,top back motor mount 17mm,14,bottom back motor mount 14mm.intake boot either 8mm or 10mm.exhaust 10mm.back of the carb to ait breather,phillips head screw driver,
    what it take to get the motor apart.cdi cover phillips screw and 8mm.camshaft bolt 10mm and pliars.vavle cover 12mm and allen wrench.cam chain adjuster screw 14mm.head to cylinder long bolt 10mm..
    also other tools,gasket scraper,wire brush,clean rags,spray cleaners,air compresser to blow oil out oil passage after all the cleaning.
    its really easy to rebuild the top end.manual helps out alot for a first timer
    Signature pic removed,becuase of no helmet.
