this will get the motor out of the frame...front motor mounts 12 mm,14mm,top motor mount 12mm,top back motor mount 17mm,14,bottom back motor mount 14mm.intake boot either 8mm or 10mm.exhaust 10mm.back of the carb to ait breather,phillips head screw driver,
what it take to get the motor apart.cdi cover phillips screw and 8mm.camshaft bolt 10mm and pliars.vavle cover 12mm and allen wrench.cam chain adjuster screw 14mm.head to cylinder long bolt 10mm..
also other tools,gasket scraper,wire brush,clean rags,spray cleaners,air compresser to blow oil out oil passage after all the cleaning.
its really easy to rebuild the top end.manual helps out alot for a first timer
