Thread: what kind of oil???
    Jul 2003
    137
    what kind of oil???
    I recently purchased a 87 honda cr 250r (2-stroke)...I was wondering if anyone had any suggestions on what of oil kind (weight, brand,ect.) to use. Not mixing oil, but oil for the components in the crank???
    Also I have no idea how much i should put in. The plug on the side of the crank case unscrews and i can see the gear's but there is no specification.
    I ordered a manuel but have'nt got it yet. I'm mechaniclly declined on some things. Anything will be helpful, thanks.
    Fresno Ca
    2,695
    Bel Ray Gear Saver 80w-90 is the only stuff ill use
    Jul 2003
    137
    thanx...but still, how much oil should i put in...maybe i should wait and look in the book huh. thanks though.
    Its a sad day..when a man can't take car of his own bike
    Fresno Ca
    2,695
    i dont know about your year but most newer bikes have a bolt that goes into the clutch cover you unscrew that bolt then fill until the oil starts coming out of it. i would post a pic of that but my bike isnt here right now most the time the bolt is closer to the front of the bike about 1/3 the way up from the bottom and not on the edge (near the center of the clutch cover)
    Apr 2003
    394
    You might want to read these links to help decide...................... 8)
    http://www.belray.com/consumer/productpages/hypoid.html
    http://www.belray.com/consumer/productpages/gearsaver.html
    84'R pic page; http://magoos.wheatfarm.com/pictures/index.php
