Is there ment to be a plastic insert in the reed cage.....can't find it on any of the micro fiches so is it a aftermarket part or oem???
Need Honda ATC TRX NOS restoration parts??? or come check out our ATC brochure site
www.offroadvintage.com
I would say it is supposed to be in there. I like how they always become deformed.
I have no idea if it original. I have found them in my old KXs though.
86 T3
84 T3
86 KX250
It's funny, I think many of us still think of allowing more volume and increasing diameters for better flow both in and out of an engine.....
I've read where opening up an intact on a thumper (not your pinger obviously) actually HURTS performance.... Mindboggling at the least!
All and all, I'm not sure if were always doing the right thing. If that belongs in there, I wonder how many people think "this is restricting it and I'm losing power!!"
So, how do we make our own test flow benches??![]()
its supposed to be there. i'm not the best to explain it, but the smaller opening is or should be the same size as the id of the intake. and the tapering helps direct the fuel air mixture into the reeds. just a wide open cage may screw up the turbulance of the mixture.
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
Mine has that in there as well. If Kawisaki put the time and effort into having that piece made to fit in there I'm sure they didn't do it to reduce the power of their race trike.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
The fuel will make more of a straight shot rather than being spread to the sides right away and may also help with suction to increase flow. One can increase volume before the reed cage but most do it after the cage.
Personally, I have run with and with out them and couldn't tell much difference.
86 T3
84 T3
86 KX250
It's there to help increase velocity.
"You should never smoke in pajamas..
You might start a fire and burn your face..
Maybe you should return to Manaugua..
You could go un-noticed in such a place"
FZ
Ass,gas or grass....nobody rides for free!
Ride free,Brotha. See you in Heaven.
thanks for the answers guys![]()
that plastic stuffer is a good thing...
2-stroke lover
Wanna sell it?
Hoosier I probably have one to sell.
86 T3
84 T3
86 KX250
the '86 stuffer is pointless if you are using a '85 intake boot...
2-stroke lover
