Got the entire frame stipped except the swingarm, can't get the bolt out. Imagine that! Been soaking it with penetrating oil every day.
Suggestions? Bigger? Torch?
1985 ATC250ES
1985 ATC250SX
1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
1985 ATC70
2008 CRF230L - Dual Sport
2016 TRX500 Foreman Rubicon Deluxe
airand right size bit. or maybe junk socket.
heat it up put a candel to the bolt hot bolt the candel wax will go into it and loosen it up keep the heat on it while trying to loosen it up
Does it spin freely? I would heat it then it it with an airand a bit that fits in the holeon the nut side,,,, Ifyour gonna replce your swingarm bearings, good luck, I just did mine and it sucked,,,,,,
2003 honda shadow 1100 spirit
94 XR600R
70 qa 50 with a 90cc motor in it
87 XR80R
82 XR500R
1972 Honda z50A mini trail,,, Finally got a stock mini
1981 CR450R
2004 chevy silverado ls ext. cab 4x4 5.3L
make sure it is spinning free and WHAIL on it with much force. Yes I did my swingarm bearings too and it really SUCKED. It also helped to move the swingarm up and down while trying to get it out. Mine hadn't seen grease in a few......years!![]()
'WHEN IN DOUBT.........GAS IT!'
87 KXT250B2 Tecate
86 ATC250ES BIG RED
85 ATC350X
85 ATC70
'A FEW IN PARTS'
I had similar problems too, the bolt siezes in that collar in the middle where no penetrating oil will ever get to. You just gotta HIT IT! An airwould probably shake it loose, but I used a big brass drift, had a buddy hold it with channelocks and banged it with a 3 pound.
Also plan on grinding out the bearing races with a dremel or air die grinder. Reach in with a long thin stone and grind a strip all the way through for the entire length. As soon as you get through all the way down, the race will be able to collapse a little and will pull right out by hand.
You can get a rebuild kit for a 1987 TRX250X from Pivot works for $50 and then just cut off about an inch of the collar and save some bucks over Honda parts. That is what I did. Just remember to cut the collar in a lathe or some way so as to not harm the heat treating.
good luck.
Looks like I'll end up beating the crap out of it then since neither I nor anyone I know has an air. Thanks
1985 ATC250ES
1985 ATC250SX
1985 ATC70
