just want to know if i should buy oem crank bearings/seals for my hotrod crank assembly. or should i use the hot rod bearings/seals? any problems with fitting if i use oem bearings with the hotrod crank? this is for an 85r, rebuilding the bottom end and top. just bored to .75 over, & ported, dg exhaust, 36mm carb. -opinions wanted please. thanks
