Just got this, had dropped a valve, put it on the bench and tore it down. head ised bad, and piston has part of the valve wedged in it. going to put xr200 top end on it. BUT pulled the cover off the left side. stator/flywheel cover and it had a LARGE amount of oil in it. BAD Crank seal I assume, have to get tool to pull the flyweel. Do I have to split the case to do that seal and can it be done after pullin off the flywheel? any suggestions while i have it on the bench? working on a tight budget. Got 4 kids, each with there own atv! You guys are a great bunch! thanks in advance.
