Results 1 to 15 of 20
Thread: Bolts snapped trying to remove footpeg
    Toronto Canada
    697
    I was trying to remove my left hand side footpeg since it was bent out of shape and I had a nicer one to replace it with, however BOTH bolts snapped when trying to remove them. I even soaked them daily with PB Blaster for a few days prior to trying to remove them, but that didn't help
    Both bolts snapped pretty close to the frame - one sticks out about 1/4" but the other is practically flush with the frame.
    I'm guessing a bolt extractor probably won't help - it's not like I stripped the head of the bolt, they were so severely rusted in place it actually snapped the bolt in half. So I have a feeling no matter how hard I try, a bolt extractor won't be the solution.
    What's my best course of action at this point? I'm thinking drilling them out then using Heli-Coil? But I thought I would ask the experts before proceeding!
    Thanks for any advice you can offer!
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Drill a hole in the bolt, put a smaller bolt in the hole, weld the new bolt to the old one and then heat the frame before trying to remove it. But I'm not sure heating the frame will be a good idea.
    What is the machine you are working on?
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Toronto Canada
    697
    Sorry - forgot to mention that... This is for my 1984 250r
    Jul 2006
    get some serios reverse drill bits, drill out till the hole is nearly the same size as the original bolt, usually at that time they loose there strengh from being stuck and roll out with the bit, doen that a bunch on various machines over the years.
    Tionesta, PA
    5,747
    i did the same thing on my 350X. Use heat and a bolt extractor (easy out).
    heat is key here!
    Those bolts are very hard - so start with a small pilot hole in the center of the broken bolt - you may be best off grinding the broken stub flat first. then move to a bigger drill bit - the self extractor should tell you what size drill bit to use.
    Toronto Canada
    697
    Thanks guys - I'm just scared to use an easy-out because i've heard horror stories that if they break off inside the bolt you are in real trouble.
    I've heard that unless the pilot hole is PERFECTLY centered and PERFECTLY angled dead-center, there's a high-chance of breaking the easy-out. I'm not sure I can make a perfectly centered and angled pilot hole.
    That's why I was thinking about just drilling it out and using heli-coil... but if you guys think the easy-out breaking is over-exaggerated I'm willing to give it a shot!
    Tionesta, PA
    5,747
    You do have to use extreme care when using these easy outs - and for a bolt the size of the one that holds the foot pegs - you will need a big easy out. One more thing that is probably never talked about when discussing easy outs. Just like any tool really - there are cheap China made ones - and there are descent quality ones. Do yourself a favor and buy a descent one for less chance of it breaking.
    Micahdogg's Avatar
    Micahdogg is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    Illinois
    378
    Buy some EZ outs. YOu may also have enough bolt sticking out to grab with some vice grips. But you'll probably only get one shot at it. It's not that big of a deal...worst case you just drill the whole thing out. Drill as precisely as possible.....centered and straight.
    (if you click this stuff, you will see pictures of this stuff)
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    1989 Thunderbird SuperCoupe
    2006 F150 Crew
    Hampton, Virginia, C.S.A.
    2,664
    this happend to my 350x with my old 85 frame and on my new 86 frame...we just went the easy route and drilled and taped it to just a little bigger then it was...and we just had to make the hole in the foot peg a slight bit bigger...but it was a pretty easy fix
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Feb 2008
    NE Indiana
    525
    I agree with atctim. Get yourself a great Easy Out, and it will work. I suggest you find one at an industrial supply shop. The best ones in my opinion are the square ones that are tapered, with ground sharp edges. You need to heat the bolt first to loosen it, then remove it with the easy out. Most people try to remove bolts when they're still stuck, but the EO won't hold up to that much torque. Get it loose first, then spin it out. The corkscrew, or reverse spin easy-outs can make it worse, although they do bite well. In the pictures below I recommend the ones on the left, and not on the right.
    smvorndran
    Attached Thumbnails Attached Thumbnails 6912d7pcseasyout.jpg   1218a6pcspiral.jpg
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    I've only used the ones on the right (good ones and cheap ones) and had pretty good luck with all of them. And I've always done so with the bolt still stuck. If I could get it unstuck....I wouldn't have broken the head off. Also, if it's unstuck you can just tap it out with a flat head screw driver.
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
    May 2007
    Coshocton, Ohio
    1,815
    Good points on using quality tools and heat to loosen it up. I've said this before but I'll say it again. I use a mig welder and weld small welds one on top of another until there is enough material to grab onto with vice-grips and then back the broken bolt out. You need to do it while it's still hot. I have about a 98% success rate with this method. I've also used it to remove bolts that had broken e-z outs and drill bits in them when those methods failed.
    Appalachian American Racing
    the home of
    Mar 2007
    Texas
    5,045
    if it's something not engine critical, i would jsut drill the bolt to the currnet size and re-tap the hole. if your lucky it will tpa it completley out w\/o damaging it, if it won't you still have a new clean hole. the 2 peices of metal can get so rusted they won't seperate as the heat fomr the rust and corrusion over time can weld parts together. so it may be easier to jsut get the correct tap for the oroginoal sizse and bit and drilla nd tap new holes. on the one sticking out, gring it flat to the frame so it's flush.
    ________________
    https://www.mikesatvfix.com
    Dec 2002
    Orange County, NY
    1,772
    Everyone else has mentioned it but it can't be mentioned enough.
    HEAT HEAT HEAT HEAT
    Get yourself a MAP gas torch and a good quality set of EZ outs and reverse drill bits. You own a 25 year old off road machine, you're gonna need those tools again.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC125M
    Apr 2006
    Crestview, Florida
    2,429
    I've got the same problem and haven't had much luck drilling into those stupid bolts. Is there a certain type of bits you guys recommend?
    Rides
    85 ATC350X
    85 ATC200X
