i just installed a new boss racing billet bearing carrier, rode the bike for about an hour, and the new bearings now have play in them. could i have a bad axle?
1986 350X
1987 200X
1984 200M
retighten the axle lock nuts and see if it helps.
how was the axle where the bearings ride? Was it all jacked up and pitted?
1986 Tri-z
1985 250r
1985 200s
1985 70[/SIZE]
the axle looked fine
1986 350X
1987 200X
1984 200M
The axle nut needs to be re-tightened. Don't go crazy on it though. Overtightening it can destroy the bearings quicker than leaving it loose will.
John
1985 Eddie Sanders ATC330r
1986 Monstecate
1984 ATC70 (awaiting 125cc transplant)
1984 ATC125M
1986 GSXR 750 - Keepin' it old school!
1999 Arctic Cat 500 4x4 plow machine
1999 Arctic Cat Thundercat 1000 (lake lizard)
1996 Arctic Cat Jag 440 L/C (ditch banger)
WWW.HREATV.COM
I don't know if I would do that. All the articles I've read say to snug it. The lock nut is supposed to keep the collar nut from loosening up so there's no reason to crank the hell out of the collar nut. All that does is potentially put unnecessary side load on the bearings. Once the play is gone from the axle there is no point in cranking down on the collar nut much further. Leave that alone and tighten the crap out of the lock nut that butts up against the collar nut, wrap the collar and lock nut with electrical tape to hold them even better in place and call it a day.
John
1986 Monstecate
1984 ATC125M
the problem is!!!!! the spacer pipe is worn,, you should have no slack between the bearings and the pipe!! NONE ,,,,, then you can tighten it up TIGHT like its supose to be!! with it almost tight it will ruin everything because its not TIGHT!!! IF THERE IS NO SLACK IN THE PIPE THERE WILL BE no SIDELOAD ON THE BEARINGS,, thats the way it was when it was new, so it should be the same now to be right. if the pipe is worn get it fixed properly,,, your bearings will last for years ,,,,
