Results 1 to 7 of 7
Thread: So how do I get these things to work?
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    Ok, the schematics I've looked at are incomplete. I need to know what I need to get from the lightbulbs to the plug on the wiring harness on a 350X for headlights. If you got what I need that would be even better, please shoot me a PM if you do.
    Thanks,
    Brian
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    if i read you correctly you need the handlebar switch.
    Halifax, PA
    400
    Quote Originally Posted by MR ATC
    No man. Sorry I'm probably not as clear as I should be. I got the handlebar switch and such. What I need is the wiring, sockets, and whatnot that stretches from the bulbs to the hookup on the trike's wiring. I'm not sure if that hookup is part of the switch or part of the main harness but its there and I got good current to it.
    Halifax, PA
    400
    Anybody? Pictures? Part numbers? Complete schematics? Parts for sale?
    roofinggun is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    202
    wiring schematic
    This is from a service manual. Hope it helps.
    ok i think i know what you need and i have them. i'll take a pic tommorow and tell me if its what your looking for.
    Halifax, PA
    400
    OK, I have this mystery partly figured out. Judging from this pic, what I need is bulbs (I might have some.) and the sockets/wire leads that you can see the ends of in the picture here I got off eBay. The question is, what would take me from that pair of 3 wires open, to the 3 wire connector on the wiring harness? I am putting these lights on a 250SX but according to what I've seen in schematics, the headlight connector is the same for both the X and SX. So I should be able to use w/e the 350X part is w/o modification, right?
