Results 1 to 7 of 7
Thread: New Guy with a Kawi KLT 250
    Wolf Lake, Mn
    9
    Hello Fellas! Name is Kenny, 47 yo. Been into snowmobiles my whole life, had a dirtbike in my early 20's in So-Cal, had Bikes most of the time, But only rode friends 3 wheelers back in the day, never owned one till last year.
    Was given a Yamaha yt 125 that was WORN out. Too many things wrong to get it going. Then I got this Kawi. Man, its in great shape for sitting so long. It has one issue I am fighting with right now. The slide in the carb keeps gumming up. Even after cleaning the WHOLE fuel system out, (standard proceedure for old sleds), and running fresh gas and sea foam thru it for about 4-5 miles, and 2 weeks time. Anyone have a suggestion as to where to look for the solution?
    Thanks for the help, And awsome site!!!
    Later,
    Kenny
    ThinktwiceZ71's Avatar
    ThinktwiceZ71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ogdensburg , Ny
    273
    hmm , the gunk must be comming from the tank , do you have an inline fuel filter installed ? try that and see if that helps limit the crap getting in your carb
    And Welcome to the site
    1985 ATC 250ES Big Red
    1985 ATC 350x DG Exhaust , Wiseco 10.25:1 .20 over - Sold
    1985 ATC 200s - SOLD
    Apr 2009
    Texas
    30
    Looks just like my KLT200 that I picked up tuesday.... but I don't have all the cool racks.
    It took me a couple hours to get my carb unstuck.... and I cleaned the heck out of the tank and replaced the hoses, pump (cause the pump was shot) and the filter. I soaked my carb in a bowl of carb cleaner with the bowl off and left the floats. I pulled the needle and tubes off the bottom and sprayed cleaner through them, and let them soak for a good while as well. The bowl on mine had about 1/4 inch of varnish sitting in it. After letting it soak I used a copper brush to get it fixed up.
    Apr 2008
    NW, IND.
    842
    Very cool ride Kenny, I use Chem-Dip carb cleaner for my machines(most Auto stores have it) and it comes with a basket for dipping, just make sure there are no rubber, plastic parts on it. It's good for cleaning other gunked up parts too. +1 on inline fuel filter. If the tank comes off, I would clean it too. Maybe even use a tank liner if it's bad. Good luck Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Oct 2005
    Cheyenne, Wyoming
    66
    Damn, that one is even cleaner looking than the one I just picked up... http://www.3wheelerworldforums.com/s...ad.php?t=95823
    You said you cleaned the entire fuel system. Is it possible the the slide spring is broken/weak? What is gumming up the slide, old bits of varnish? Is the carb cap seal good? Maybe sucking some dust in through the top? Fuel pump clean inside? They can hold bits of varnish too. New fuel lines, same problems? Just some food for thought.
    Gary
    Nuke Em til they glow, Shoot Em in the dark!
    1986 ATC250R
    1982 KLT250
    1980(?) ATC110
    1984 ATC70
    1983 ATC70
    1983 ALT50
    (4) 1985 FL350R Odysseys
    1983 RM125
    1980 185 enduro
    1990 LT250S
    2005 Suzuki Eiger
    kids gokarts (4)
    Wolf Lake, Mn
    9
    Thanks for all the suggestions!!!!
    I tore it down twice today and I "Think" it is Varnish coming from the tank. It is gumming up the whole slide and the engine side of the carbs bore. So I will try to get the tank off and rinse it out since it must be breaking the varnish up in there.
    Again, THANKS!
    Later,
    KEnny
    " Just cuz ya got tools don't mean you're a mechanic!"
    My Dad
    Apr 2009
    Texas
    30
    I used carb cleaner to clean out the tank.... I sprayed and then swished it around. Over and over and over. Mine was bad.
