Results 1 to 15 of 24
Thread: Metal Hardening..the home way?
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    OK guys, putting the group collective knowledge to the test here. Lets suppose I want to harden something, like a transmission gear, or shaft, in my shop. What are my options, and courses of action?
    Jackson MI
    1,688
    when I was younger I read that you could harden Gm turbo 350 Intermediate spraggs In your oven. I think the article I read was In a car craft magazine It needed to be heated to 500 degree's for 30 minute's. I can find out more Info If you want, I have a couple friends that make some crazy stuff, and have lots of parts heat treated right here In town.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Live Oak, FL
    15,069
    That would be very helpful Jason, thanks! :
    Jackson MI
    1,688
    What are you trying to do? I'm sure I could get It done CHEAP!!! This part of the world Is kinda slow because of the Economy.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Jan 2005
    Jones, Michigan
    1,821
    buy a "curing oven" or whatever its called like my shop teacher had and cook it for a few hours, you can heat it up and drop it into some motor oil too but that will make it "fragile", yet very hard i think....
    Hey jason CALLL ME
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Oct 2007
    Minneapolis mn
    4,067
    Heat it with a torch and put it in oil a few times... Acts as more of a case hardening... wont make it brittle... We have done it a few times in our shop... Not a heavy duty enough procedure for something like the wheels on our english wheel with a hardness near 55, What are you trying to harden?
    Apr 2008
    NW, IND.
    842
    +1 on case hardening with heat and oil. To get it deeper, I've preheated hard steel and then welded hard surface rod (very hard to do without undercut or cracking) to it then turned, milled it to size. Beets
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Live Oak, FL
    15,069
    For the sake of discussion, lets say a connecting rod
    I have no idea on the hardness scale what that would need to be. I have heard of "oil quenching" before, but didn't really know wht it was before you guys mentioned it here, thats very interesting. So if the whole part was cherry red for a bit, and then threw it in a bucket of oil (wonder what weight and viscosities, how that effects it? I'd assume that thicker stuff would be a longer cool down time?) thats an effective way to harden a part?
    Dec 2005
    Wisconsin
    1,141
    Oil quenching is a great way to harden a part with out making it brittle like when you quench with water. If you want to case harden something you need to heat it for a length of time in carbon. I can dig out a book from last semester and find formulas if need be for this kind of stuff.
    In your case with a connecting rod I would heat it to a dull orange, not cherry red and dunk it in USED motor oil. The used oil has much more carbon in it and this acts like case hardening.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    I thought freezing engine internals was batter. That is what I am having done when get get started on my 7.3 twin turbo biuld.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    May 2007
    Coshocton, Ohio
    1,815
    Work hardening is another way to harden steel. Get yourself some basic info on blacksmithing. I love working with metal. My specialty is sheetmetal.
    Appalachian American Racing
    the home of
    Apr 2008
    FL
    144
    Here you go Billy..
    http://www.google.com/url?sa=U&start...adkkkOAVK0giQw
    Careful how you heat up the item you want to harden. If you don't heat it evenly you can induce some twisting and other nasty things.
    If you really want to make something special, harden it and then send it out for cryo treatment.
    From experience, Cryo treatment works all by itself too. Story to follow..
    Several years ago a friend of mine raced a highly modified E Production Mazda Miata in the SCCA on a national level. Very competitive field with very restrictive rules on what you can and can not do. One of the areas they restricted heavily was brakes...(go figure, such a dumb area to restrict). Anyway, he used to go through a set of rotors every other race and TWO sets of rotors every time they ran Sebring....
    After trying everything else we sent the rotors out to get Cryo treated. After treating the rotors they would go an entire season....and still not be beyond usable.
    Anyway, that's my contribution there Billy. The crystal structure of various types of alloys is very unique between them all. Read as much as you can before testing anything out on an expensive part!!
    Good luck!
    -BFC
    '86 250R
    Live Oak, FL
    15,069
    I appreciate all the input guys, hopefully I might get to put this to the test sometime soon
    PA
    3,515
    i just read about this in my machinist book..... i'll post what it says when im not on the ps3
    WWW.HREATV.COM
    May 2007
    farley Ia
    84
    It depends on the metal. The big difference is how you cool it down. some metals you need to quench in water, some in oil, and some just air cool. If you have a metal that needs to be water quenched and you air cool it it will not harden. it might actually aneal it and be softer. If you water cool a metal that needs to be air cooled you WILL crack it(been there, done that, spent the money ).
    For something as important as a rod I would go to a pro. Also, would you want to harden a rod. I would think it would break faster because it compresses and stretches every cycle. Maybe case harden it but like stated before, that needs to be packed in carbon and air tight.
