Results 1 to 15 of 16
Thread: 200x Kicker gears....
    Dec 2005
    Wisconsin
    1,141
    Hey guy's got the new engine together and who knew the kicker gears are . When I had it running last fall they worked fine. Now that I have heavy valve springs, and a 10.25:1 comp piston in it the kicker teeth aren't liking it. Few questions, would new internal gears and a spring solve the problem or should I fire up the bridgeport and back cut the teeth so they are angled to grab into each other when they engage. Or would simply stiffening the spring that engages the teeth solve my problems? The teeth looked good when I had the cases split that's why I reused them. I think I am going to run it for the summer as long as it doesn't get any worse, that will give me some time to evaluate the situation and find a good solution. ...and I don't want to tear this mother apart again...
    Thanks for the help if anyone has any advise.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    Howdy's Avatar
    Celina, Ohio
    10,079
    A little heavier spring and back cutting the gears should solve the problems.
    Howdy
    Dec 2005
    Wisconsin
    1,141
    Sounds like I have work to do. You don't think a heavier spring alone won't fix the problem? And where do I find a stiffer spring for this guy, or am I just going to have to shim the spring with a washer?
    1985 Honda 200x...
    rugabugadouglas's Avatar
    rugabugadouglas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    iowa
    269
    i had the same problem with my 12:1 piston so i fixed the gears and got a goki starter too then i pulled it and made a auto x lol
    louisiana
    1,499
    use a head with the decomp lever.thats how my 200x is setup and i have no problem kicking it over.
    Signature pic removed,becuase of no helmet.
    Danold's Avatar
    Danold is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    barnesville, Ohio
    193
    When I took mine apart the teeth didnt look rounded and gears looked good but it turns out they werent. I took it back apart I cut a spare spring from another kicker gear in half and put it in there. It hasnt sliped yet and that was last summer. As long as the teeth are not rounded, this will work.
    85 200x
    85 Tri-z
    86 Bigred
    81 Rm60
    John Deere racing tractor
    Quote Originally Posted by wad
    sorry dude mine are all shitters lol
    Dec 2005
    Wisconsin
    1,141
    Quote Originally Posted by Danold View Post
    Thank you sir! This is good to know as mine looked nice and sharp like new so I figured they were good to go.
    And Lee the decompression part is just in the rocker box cover right? Do you know what models had these that will fit on the 85 200x? That would be the easiest fix at this point.
    1985 Honda 200x...
    I thought the 200M and 200S had the decomp lever in the head....?? Not my models though so it's a guess. I'd look at parts on EBAY or start a new thread on the decompression lever......
    On a side note, I had an 85R with slipping gears. Back then, I was broke and 125$ in parts was allot! I was very disappointed when I got the new gears because they too did not have the sharpness I felt they would being new.
    But, for whatever reason, they did fix the issue. I just thought I'd see teeth as sharp as knives!!
    I think allot of that <85 200X issue is the spring itself. But, don't go overboard. A strong engagement spring will also bump off those good edges on the gears as it slips back on by on the upstroke.
    Problem is, that all your stuff is internal and tough to get at.
    DADS did claim to have figured out what shim he felt worked well. I'd PM him and see if the ones that got modded are still working well.
    And if that spring alone can be bought new, I'd grab one up!
    Good luck : Thats one of Honda's worst designs..........
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Greenhuman made a post on here a while back, and Raffa followed up with some pictures on how you can file the teeth on the ratcheting mechanism to grab and pull itself together better. I can't remember the name of the thread but it is floating around here. Might be in the mad scientist lair.
    Apr 2006
    Crestview, Florida
    2,429
    I've got a 200e head in my shed that has a decompression lever. If you need it let me know, i let it go very cheap.
    Rides
    85 ATC350X
    85 ATC200X
    louisiana
    1,499
    never said the 200x cam with a decomp lever.i said that's how mine is set up.according to babbits all this models should have the same head with a decomp lever.
    Sku Model Description Req Price View
    12000-427-010 View Sku Supersession
    Loading...
    ATC185 A (80) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# TB01-2000013 TO TB01-2027332
    Assembly: CYLINDER HEAD
    CYLINDER HEAD ASSY. (Honda Code 1079136) (SKU: 12000-427-010) (Superseed: 12000-427-305) 1 $310.08 Add to Cart [Click to view details]
    Loading...
    ATC185S A (81) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB010-BC100008 TO JH3TB010-BC144020
    Loading...
    ATC185S A (82) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB010-CC200001 TO JH3TB010-CC283136
    Loading...
    ATC185S A (83) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB010-DC300013
    Loading...
    ATC200 A (81) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB050-BC000004 TO JH3TB050-BC036208
    Loading...
    ATC200 A (82) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB050-CC100001 TO JH3TB050-CC156772
    Loading...
    ATC200 A (83) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB050-DC200023
    Loading...
    ATC200E A (82) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB051-CC133783 TO JH3TB051-CC174752
    CYLINDER HEAD ASSY. (Honda Motorcycle Code 1079136) (SKU: 12000-427-010) (Superseed: 12000-427-305) 1 $310.08 Add to Cart [Click to view details]
    Loading...
    ATC200E A (83) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB051-DC203548
    Loading...
    ATC200ES A (84) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB055-EC307605 TO JH3TB055-EC516032
    Loading...
    ATC200M A (84) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB054-EC300005
    Loading...
    ATC200M A (85) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB054-FK400001
    Loading...
    ATC200S A (84) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB053-EK300001 TO JH3TB053-EK315150
    Loading...
    ATC200S A (85) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB053-FK400004
    Loading...
    ATC200S A (86) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB053-GK500006
    Loading...
    TRX200 A (84) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TE030-EC000007
    Loading...
    XL185S A (79) MOTORCYCLE, JPN, VIN# L185S-5001103 TO L185S-5017934
    Loading...
    XL185S A (80) MOTORCYCLE, JPN, VIN# MD02-5000003 TO MD02-5009422
    Loading...
    XL185S A (81) MOTORCYCLE, JPN, VIN# JH2MD020-BK200002 TO JH2MD020-BK210000
    Loading...
    XL185S A (82) MOTORCYCLE, JPN, VIN# JH2MD020-CK300003 TO JH2MD020-CK307487
    Loading...
    CYLINDER HEAD ASSY. (Honda Code 1079136) Use up to Engine SN 5306414 (SKU: 12000-427-010) (Superseed: 12000-427-305) 1 $310.08 Add to Cart [Click to view details]
    Loading...
    XL185S A (83) MOTORCYCLE, JPN, VIN# JH2MD020-DK400003
    Loading...
    XL185S AC (83) MOTORCYCLE, JPN, VIN# JH2MD021-DK400004
    Loading...
    XR185 A (79) MOTORCYCLE, JPN, VIN# ME02-5000061
    Loading...
    XR200 A (80) MOTORCYCLE, JPN, VIN# ME02-5100012 TO ME02-5107049
    Loading...
    XR200 A (81) MOTORCYCLE, JPN, VIN# JH2ME020-BK200001 TO JH2ME020-BK202164
    Loading...
    XR200 A (82) MOTORCYCLE, JPN, VIN# JH2ME020-CK300004 TO JH2ME020-CK303395
    Dec 2005
    Wisconsin
    1,141
    Thank you Lee that clears up that issue. Now I need to hit the local junk yard and ebay.
    1985 Honda 200x...
    Sep 2007
    100mi west of Chicago
    3,582
    Does the decomp lever make it that much easier to kick over? I just got mine back together yesterday with a bore and Wiseco. I can get it started but only if I get a smooth fast kick on the exhaust stroke. If it's on the compression stroke, forget about it. Sometimes it also seems like it binds. My shin is bruised and swollen today
    Rob
    louisiana
    1,499
    mine has a wiseco and also a xr200r cam.with the decomp lever it is easy enough for my gf kick.
    Sep 2007
    3,582
    Maybe I will give it a try. I have a valve cover from an 81 185s that has a decomp lever. So it's not a big deal that the cam wear won't match the lobe wear?
    Rob
