Are there numbers on the casing of the 86 motor that will tell if it is an 85 or 86 with it off the frame?
Will the carb from an 85 work on an 86 ok. Beside the 6 gear are there other differences?
Thanks
sheeptender
Thanks
sheeptender
Just-Tri-It
:Trikes Owned:
1985 Tri-z's 3
1986 Tri-z
1984 YTM 200ERN 1
85 case 38W 86 case 1RX
Carbs will interchange as well.
Will the clutches and carbs interchange even though they have different parts number?
Thanks
Just-Tri-It
:Trikes Owned:
1985 Tri-z's 3
1986 Tri-z
1984 YTM 200ERN 1
