Results 1 to 7 of 7
Thread: 84 200x help
    Apr 2009
    leesport
    15
    Unhappy 84 200x help
    hi everyone, recently i picked up an 84 atc 200x. the guy i got it from used to race it and ran alcohol then when he switched it to run gas he leaned it out and cooked the rings. so i got it for free put a stock piston in it and honed it a little to get rid of some fine groves, and used new gaskets, started it up and it ran good smoked but ran good, so i drove it for about 30 minutes then it just shut off. tried starting it but nothing. its getting fuel and it has great spark. i thought that maby it was the timing so i checked that and its fine.
    im completly stumped. wat can i do to fix this or what is wrong. thanks tom
    Sep 2007
    100mi west of Chicago
    3,582
    How is the compression?
    Rob
    Apr 2009
    leesport
    15
    it has the same compression as when i first started it to after it shut off, thanks
    Sep 2007
    3,582
    I guess check airbox leaks, electrical connections like the killswitch wiring, plugged fuel line
    Rob
    Apr 2009
    leesport
    15
    rigth now airbox is not hooked up, oh and it has a bigger racing cam in it also. ill check the wiring. im just really stumped on this one. it dosent take much to make a 4 stroke run, fuel compression spark. i also ordered a new carb for it, thanks
    Sep 2007
    this has happened to me if it is not getting oil to the top end and the cam with siece u can tell if this happened bc it is a little bit harder to kick over
    Apr 2009
    leesport
    15
    maby ill check that but its not hard to kick, or harder anyway. from what i read it has a stage 2 cam in it. im thinking the timing has to be off. after a ton of kicks it will pop out the exhaust. and it feels like theres air coming from the exhaust and the carb when u kick it, so maby a bent valve or something, thanks
