Thread: Honda 185 Performance
    Apr 2009
    Sparta, WI
    4
    Can you get performance parts for a 185 Three Wheeler mainly engine performance.
    Sep 2007
    100mi west of Chicago
    3,582
    185 and 200 engines can share top end parts, so you have quite a few options as far as hop up parts go.
    Rob
    Baltimore, MD
    6,088
    Your best hop up parts are 200x parts, but then you will be overstressing the auto clutch assembly and may have problems. You are better off with a 200x. People will invest more money into hopping up a 200s engine than they will pay for a 200x engine. Doesn't make any sense to me. Good luck with your project though.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Feb 2009
    Rome,NY
    1,046
    there was a 185 pipe on the bay recently that with a xr 200 carb and intake should do the trick
    Feb 2008
    Orange County California
    726
    Vealmonkey has a valid point. I am not sure about you, I love my string puller, but you can't go wrong with a suspension bike. If performance is what your after, then it will most likely be cheaper going with a 200x, 250r, or 350x
    What are your plans? whatchya wanting to do?????
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Theres alot you can do with those motors, cam, high comp (12:1) piston, XR carb, DG or Cobra pipes, even Bassani if you can find one. All depends on how much you want to put into it.
    TF 07,08,09,10,11,12,13,14!
