Thread: 350x Front Brake Caliper Problems
    Vicksburg, Michigan
    5
    So I bought a 350x front caliper on ebay since it didn't have one on it when I bought the bike. When I go to mount it tonight the mounting bolts line up, but when I go to tighten them it appears that the caliper isn't situated correctly, and binds up against the rotor. Is there a couple of spacers I'm missing between the fork and the caliper, or could it be that the front spindle is not sitting in the correct spot? Everything related to the spindle appears to be tight and correct, so I'm stumped. Thanks
    Dec 2002
    Orange County, NY
    1,772
    I ran into a similar problem when I tried to use a 350X front hub and rotor on a 250R front end. They look really similar and I would have bet money on them being interchangeable but they weren't. Maybe someone swapped the hub/rotor to an R one at some point.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC70 (awaiting 125cc transplant)
    1984 ATC125M
    1986 GSXR 750 - Keepin' it old school!
    1999 Arctic Cat 500 4x4 plow machine
    1999 Arctic Cat Thundercat 1000 (lake lizard)
    1996 Arctic Cat Jag 440 L/C (ditch banger)
    Apr 2006
    Crestview, Florida
    2,429
    sounds like the slides are stuck in the caliper, try removing the caliper bracket and you'll fing out.
    Rides
    85 ATC350X
    85 ATC200X
    Vicksburg, Michigan
    5
    Okay, it looks like the tire sits off to the left side a little more if you are at it head on. Would that be an indication that it is a R front spindle assembly?
    Dec 2002
    Orange County, NY
    1,772
    It could also be what Eric mentioned.
    Sorry, I can't give you more info on the hub possibility, its been close to 9 years since I did that.
    John
    1986 Monstecate
    1984 ATC125M
