Results 1 to 15 of 15
Thread: can you put oil in a thumb throttle cable?
    Holland, NY
    635
    Ok this might sound really dumb but im 14 and i oiled my clutch up and i liked the feal so i went ahead and oiled my thumb throttle is that bad to do this? i remember when i took my dx carb apart and rebuilt it the cable came to the main jet...now im worried about ruining my machine...Someone PLEASE help Thanks!
    TRIKES:
    1985 Yamaha YTM 225 DR Special Edition
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    2001 Ski Doo MXZ 600
    1997 Ski Doo MXZ 583
    Dec 2002
    Orange County, NY
    1,772
    Its good to lube the cables. Don't worry about the oil getting into the carb. Just use common sense as far as how much oil you put in.
    John
    1985 Eddie Sanders ATC330r
    1986 Monstecate
    1984 ATC125M
    Feb 2009
    Rome,NY
    1,046
    Yeah you should be fine great job !!!
    Holland, NY
    635
    ok thanks man i just got this and i figuired the cables and everything might need a little attention...
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by Kerick View Post
    A good lubricated cable will last a lot longer than a non-lubed one. Very good for preventitive ( sp? ) maintance. Thumbs up for doing the correct thing!!
    Howdy
    Feb 2009
    michigan
    2,387
    oil a cable
    good intuition kid.i have always oiled my cables.they will last longer.water is the enemy here,water in a cable will destroy a cable prematurely
    1985 ATC 250R
    . Team Red Trike
    Bartlett TN
    3,083
    I used to just stick the cables in a bucket of oil and let it sit for days. Usually helps the cable move more freely and protects it from rusting.
    86-87 Tecate ROCK!
    Tionesta, PA
    5,747
    there is actually a product on the market ( I have one) just for lubing cables. It is slick - here is what it looks like.
    We lube our cables all the time - it is great preventative maintenance.
    Jan 2005
    Jones, Michigan
    1,821
    hey atctim, how do those things work? i've always been curious as to how to use one and how good they worked.
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Feb 2009
    Wisconsin
    521
    What do you lube them with?
    1985 Auto X lots of upgrades
    1982 Honda 185s 3inch wheel spacers, bassani exhaust
    2001 400ex
    1983 110
    Tionesta, PA
    5,747
    You pull the cable off the what it is hooked to - whether it be the clutch perch or brake or what ever, You then slip the cable into this device and clamp it down. This puts a rubber seal around the outer cable sheild, and the actual cable. You then insert the little red hose that comes with WD40 and other penetrating oils in the little hole, and sqray away .It basically works like a tiny funnel getting the lube down inside the cable.
    Holland, NY
    635
    i used like 3in1 oil its in a metal can with a dropper type lid
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    Holland, NY
    635
    where can i get one of those???
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    Little Britain, Ont, Canada
    82
    Any shop should have them, there dirt cheap also. You have to use spray lube with it.
    81' ATC200
    85' 250R
    Jul 2006
    iowa
    451
    That cable luber looks pretty slick. What I do is cut the corner off a plastic sack, dump oil into the corner piece, and then use black tape/small zip tie to fasten it to the end of the detached cable. Then you can GENTLY squeeze it like a bulb until oil comes out the other end of the cable. (yes, you will get oily. also, a piece of heavier plastic works better)
    current rides:
    05' 400ex
    02' yz85
    84' 200es big red
    84' 200s with tlr200 engine project (almost done)
    84' atc 110
    83' 225dx with 340cc kohler sled engine
