Results 1 to 15 of 25
Thread: welding a honda 110 frame
    Apr 2009
    Oklahoma
    1,234
    can this be fixed?
    Attached Thumbnails Attached Thumbnails untitled.JPG   untitled2.JPG   untitled3.JPG
    Jun 2006
    Willow, Alaska
    1,337
    Got pics of the damage?
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Anything can be fixed, that does look horrible though.....
    Can't you find a used frame? Shouldn't be expensive or too bad to ship either.
    To weld that correctly and make it safe, it's gonna be a few bucks unless you've got someone that hooks ya up.
    Apr 2009
    Oklahoma
    1,234
    i have another 110 but all the brackets are drifferent
    Jun 2006
    Willow, Alaska
    1,337
    If you spent a while cleaning those welds off, you could probably repair it. Id try and put a piece of pipe or find some way to brace the frame.
    -Nick
    Apr 2009
    Oklahoma
    1,234
    here are the 2 frames
    Do you have someone who can fix it properly? for a reasonable cost? Something to think about anyhow.....
    I imagine a 125M frame is completely different? I have one you can have for free (pay shipping) if it would work for you.....
    Apr 2009
    Oklahoma
    1,234
    do you need any parts? 200s,m?
    Baltimore, MD
    6,088
    There is no way I would even begin to try and fix that busted up frame. There are just too many used frames to even worry about such things. I would try and go with an aftermarket frame. I've had several aftermarket frames and sold a few for what I bought them for. There was an aftermarket 110 frame on ebay the other day. You might want to look into that.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Quote Originally Posted by tulsamike3434 View Post
    No, I honestly have very limited knowledge on all these E,S and M machines and don't own or ride them. Great machines though
    I'm more into the sport/race trikes and the ATC70.
    Vealmonkey has ALLOT of experience and take his advice as etched in stone......
    I just didn't know if the 125M would be any help. I got one for short $$ just to part out and it's been under a tarp for a bit.
    Baltimore, MD
    6,088
    I never tried switching any parts to a 125m frame. Heck if you have a 110 roller, I know you can bolt a us90 engine in it, even the later model 85 frames with the adjustable rear axle. You just have to keep in mind about all the parts you need with a certain year frame. I've had 85 fenders on a 1980 frame. So alot of the 90/110 stuff will swap around, but there are certain parts that work on certain years and just won't mix and match. Learned some of this the hard way. Certain year brake parts are very specific. You can switch wiring harnesses but you have to keep a cdi harness with a cdi trike and a points harness with a points trike. I've only worked on one 125m, and it was kind of a pain, but I never swapped any parts out. It really depends on your budget what you want to do. A stock frame will work fine, but they have their limitations. Now most stock frames are at least 23 years old and they are stamped steel. You have to be very careful. And some people have jammed every kind of american nut and bolt into them at one time or another. Make sure you have a good tap and die set and lots of wd40 or pb blaster or whatever you use for a thread lube. And take your time. And above all, do some research and have a factory manual or a factory pdf from the web. I'm not the 90/110 guru by far, it just seems that no one on here is as dumb as me to keep fooling with this stuff. Shop around till you can find a frame that is pretty close to the same year what you have and that will help alot. A wiring harness from a trike with the light switch on the headllight is not a direct bolt up for a headlight switch on the handlebars. 82 and earlier brake parts, won't work with the 83 and later brake setups. Certain year frames have the mount for the coil on the inside of the frame. Tank mounts are slight different on certain years. They just aren't all easily swapped out. And becareful, a deal on a frame might not be a deal if it doesn't work on your trike. Your about to learn alot about trikes. Do a little research and have fun. If you don't have a decent set of metric wrenches, you might shy away from doing this. You will be stripping nuts and bolts out left and right if you just have a couple adjustable wrenches. Just buckle down and have fun.
    Nicholson 185s
    Apr 2009
    Oklahoma
    1,234
    thank you so much for your input. i love this site and this thread is one of the main reasons why. thank you all for thr input.
    Oct 2007
    Minneapolis mn
    4,067
    I would cut that spot out of the frame and weld in a new piece... Granted I am a street rod fabricator, and cut and weld pert near everything...
    Apr 2009
    Oklahoma
    1,234
    I'm going to try to weld it this weekend. My friend bought a new welder he is comming over sat.
    here are some more pics. Click on them to see the full size pic.
    Whatever you do, you gotta get all that snot off of there first. That stuff is bad.
