Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: welding a honda 110 frame
    Apr 2009
    Oklahoma
    1,234
    Whatever you do, you gotta get all that snot off of there first. That stuff is bad.
    I know thats right! I was thinking about cutting another frame and putting it in that spot. The other frame is the wrong 110 frame none of the clips or mounts are right.
    greythorn3's Avatar
    greythorn3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2007
    ALASKA
    302
    wow those are some horrible looking welds! who did them?
    1985 big red 250es working good. 1983 200e waiting for new crank and rod. 200x project looking needing everything.
    Apr 2009
    Oklahoma
    1,234
    I don't know I bought it that way in a big lot I found for 100.00
    Apr 2009
    Oklahoma
    1,234
    The weldz look like bubblegum lol
    Apr 2009
    Oklahoma
    1,234
    There is no way I would even begin to try and fix that busted up frame. There are just too many used frames to even worry about such things. I would try and go with an aftermarket frame. I've had several aftermarket frames and sold a few for what I bought them for. There was an aftermarket 110 frame on ebay the other day. You might want to look into that.
    Where can I find them I searched and came up with nothing.
    Jun 2009
    Leander TX
    2,217
    Which one of your frames is messed up - the one on the left or the one on the right with the coil on it?
    I have an 84 110 frame that looks like it's in pretty good shape. It's a CDI year and the axle housing moves to adjust the chain. Let me know if it will work for you. We can work something out - I have a 200s project in work.
    Feb 2009
    michigan
    2,387
    grind all that chit off first.dont grind into the frame,just the weld itself.then cut out a patch from something similar in thickness,and similar steel.and weld on the patch.it is do-able.
    1985 ATC 250R
    . Team Red Trike
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    Quote Originally Posted by harryredtrike View Post
    Thats exactly what i would do. Even if you had to take it to someone it shouldnt cost ya that much...
    Apr 2009
    north tonawanda ,new york
    133
    its an easy fix. 1st you got to grind all the off, cut out any rot 2nd cut out some plates to cap the sides then take a pipe that is i bit bigger than the tube , cut that in half to cap the tube and weld it up be sure to make your plates bigger than the area your covering . well thats my 2 cents hope it helps ...
    May 2009
    Brampton, ontario
    686
    angle grinder, and just cute that section right out, get a small peice of iron pipe. probably will cost.. 3 - 4 bucks worth of pipe lol.
    Looking for some smaller style tires like the r's have, just 2 back tires. pm please.
