After doing wheel bearings and differential on my 250SX, the rear brake doesn't return properly. I've read a couple threads that suggest it's the cam that needs to be removed and greased. That makes sense to me.
So I'm planning to take it apart in the next few days, but I wanted to ask two questions for anyone who has done this:
1. In the Honda diagrams, there is an oil seal and dust seal on the cam shaft on the side where the brake lever and cables attach. Is this something I need to replace when I take it apart? I'd rather order and have these things on hand before I take it apart. The machine is rideable, the rear brakes just suck.
2. Should I put any grease on the surface of the cam where it contacts the brake shoes? I was always under the impression that you don't ever want any oil or grease inside the brake drum. I assume it would tend to migrate and end up on the shoes, which is obviously bad, but someone suggested that in one of the threads I read.
Thanks in advance!
