Results 1 to 7 of 7
Thread: 250R axles and bearings??
    Might as well throw in bearings and seals.
    Anyone know what number bearing fits the stock 1985 atc 250R housing or seal MM dimensions?? Are thera 6000 or 6008 etc? I get them at a bearing warehouse.
    What do you do to keep the R axle and hubs nice and tigtht and working well. Any tips or problem areas there??
    One hub is already a tad loose, is that a spline worn out thing on the hub and axle usually??
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,249
    REAR BEARINGS FOR 85 AND 86 250R'S # 6908
    JUST MAKE SURE THAT YOU KEEP AXLE NUTS AND HUB NUTS TIGHT!!! ,just because there is a kotter key in them does not mean they will stay tight recheck them periodiclly
    Dec 2002
    salem, nh
    1,339
    ...and so the beginning of many posts to come begins.
    hey dirtcrasher, where in mass are u again? once i finish my 200x i should whip it around your track...or maybe i'll wait till i sell both my bikes and get the new YFZ450 so i can put it up against your R
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Quote Originally Posted by kilabeez0
    I'm south of Boston about 45 minutes, you're are more than welcome to whip it around here sometime - but the 200X will do the least damage to the track. Gimme about another month to finish making all these dam 3 wheelers running.
    Anyone know why the 250R hubs get loose??
    Is it a shoulder thing? or do the splines in both the axle and hub wear out?
    Jul 2003
    6
    Hubs Loose
    When my hubs used to get loose i found out the nuts holding on the tire wore down and started to like create friction i dont no what made it happen i just tightened them up
    My Trike is a Mut but once was a 83 Ytm-200
    Mike Fort Laud's Avatar
    Mike Fort Laud is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2002
    386
    The splines in the hubs become wore and get loose on the axle no matter how tight you make the center nut. My solution on my '85 250R was to remove both hubs,mix up some Marine Tex and put it on the axle splines,then slide the hubs back on,tighten and let the Marine-Tex harden overnight. No more loose hubs for thye past year. It takes a rubber to nock the hubs back off. I was almost going to buy new parts and thought of the Marine Tex thing and have not had one problem with the hubs being loose again.
    I would rather have a sister in a whorehouse,than a brother with a quad!!!!!!!!!!!!!!!!!!!!!! Still walking the "Tightrope"
    Dec 2002
    salem, nh
    1,339
    What is marine tex? i found out last night that my hub is loose also on my 110.
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
