Results 1 to 7 of 7
Thread: newbie to 2stroke
    Apr 2009
    Macon
    newbie to 2stroke
    I just recently aquired 3 3wheelers...2 trimoto 125's and a trimoto 175, early '80's
    All three are in differing stages of disassembly, as this is how I gtot them.
    I have never owned any two stroke motorbike, and I am a little stupid ,,,this may sound dumb to some ,but there is a oil fill hole next to the right rear tire, next to the oil pump, it says 850 cm I think. What type of oil goes there..LOL, I told you I know nothing, just thought it would be fun to try and get them running. Any help would be appreciated.
    81k is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2008
    Bowling Green, MO U.S.A.
    152
    I would say two stroke oil goes in there, but I'm unsure
    YT 60
    '85 ATC 200X x2
    YF 60
    '02 400EX
    '85 YFM 200
    '99 Scrambler 400 4x4
    '85 350X
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Quote Originally Posted by 81k View Post
    NO. NO. This is where you put the tranny and clutch oil. 850 cc is the amount needed.
    Use any oil recommended for use in 4 strokes motorcycles and you will be fine.
    I don't know where you put the 2 strokes oil on these three-wheeler.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Southern MN
    1,875
    There is a white plastic bottle under the rear fenders on the left hand side with a rubber cap you pull off and put oil in there. Make sure the oil pump is working, it should smoke blue out of the exhaust with the motor running if it is. If you dont trust it, detach the small plastic tube running to the carb, and put somthing in it to plug it. Then just premix the oil directly in the gas, then you know the oil pump cant go out. Thats only if you have your doubts. GOOD LUCK!!!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Southern MN
    1,875
    Oh, and you can use either 10w30 or 10w40 for the crankcase. Be sure to drain the old stuff out by removing the bolt (15mm I believe) on the bottom of the engine, in the center of the skid plate. Next, tighten it back up, and remove the 10mm bolt on the right side lower of bottom end. It will say somthing on the case like FILL. Pour oil into the top, where theh fill plug is until oil starts coming out of the fill hole. Quickly screw the bolt back in, and your good to go!!!!!!!!!!!!!!!!!!!
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Jul 2006
    HEY is that MACON GA?? Im a pretty busy person, but if you are from macon hit me up and bring them down and I can see what I can doto them right quick like
    May 2008
    Northwestern Ontario, Canada
    552
    I'd use pre-mix. The oil injection on these things was not too reliable, at least up here, especially in the cold.
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
