Results 1 to 15 of 18
Thread: installed brand new stator/flywheel runs 30ft dies (tecate)
    kasuki's Avatar
    kasuki is offline At The Back Of The Pack Arm chair racerFirst time rider
    gasport,NY
    205
    i bought a brand new ricky stator flywheel an stator.i installed them last weekend trike started right up i lined up the markes on the timming plate to the case.took the trike out for a ride carb seemed rich up top i had a 300 main in it .well i was on my way back down the street the trike just stoped running.so i pushed it home 40 yards i jumped back on kicked it over an fired back up runs for about 1 min then dies this has been going ever since.i tryed two different carbs i think it is electrical.i have a tone of time an money in this dam thing.i just wanna ride it.it will be 4 years on the 29th since the build began im just burned out of it.im starting to lose intrest in it an i never trail rode it i wanna get the new carb but i keep dumping money in an it never runs right.so to day i go out pull the flywheel turn the timming plate to the left of the case mark about 1/4 inch as another post did using the same set up trike starts right up.i ride about 25 yards dies,kick it over fires up ride about the same an dies.what should i do i have a manual but im stumped im not really sure how to test the electrical stuff.i am running a tether kill switch coul this be a problem.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    i have a very low opinion of ricky stator..... sounds like you have a ground problem,,, check all the wiring and make sure your kill switch is working properly,,
    Mar 2009
    Arkansas
    20
    I just used a kx250 ignition on mine ... found a scrapped out bike ... $25.00 .... saved me $$$$$ ...
    My Minty Red
    99gsxr750 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    Eastern Pa
    219
    Quote Originally Posted by junkster View Post
    Same here. It was on the trike when I bought it.
    81k is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2008
    Bowling Green, MO U.S.A.
    152
    you may try to get an inexpensive inline spark tester, start it up with tester installed, and watch for loss of spark when it dies.
    YT 60
    '85 ATC 200X x2
    YF 60
    '02 400EX
    '85 YFM 200
    '99 Scrambler 400 4x4
    '85 350X
    Dahlonega,GA. (Formerly Flint,MI.)
    787
    Sounds more like a CDI or coil issue. I've never had a single issue with Ricky Stator stuff.
    Did you time it??
    "You should never smoke in pajamas..
    You might start a fire and burn your face..
    Maybe you should return to Manaugua..
    You could go un-noticed in such a place"
    FZ
    Ass,gas or grass....nobody rides for free!
    Ride free,Brotha. See you in Heaven.
    What you are describing sounds just like what my 85 did when the stator died. Strange, though, as you obviously just changed yours.
    Have some patients with the trike. It's not the trike's fault that it's not running right. I get aggrivated sometimes too, but just put the wrenches down for the day and sleep on it. I can't even count how many times I've fixed things in my sleep, literally.
    I've got Ricky Stator stuff on mine and never had a problem.
    Sep 2008
    Northwest Indiana
    550
    Try swapping out the CDI box, had an issue this weekend in Oklahoma with my 85 Tecate. Swapped the CDI and it ran perfect. I was always under the impression that if a CDI goes out, its completely out and the bike won't run. Not the case with mine. Just a thought....good luck!
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Are you sure the key way did not break. Mine broke one day and would still start but could no go anywhere. Its the cheapest fix.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    kasuki's Avatar
    gasport,NY
    205
    na the key is good i checked .does anyone have a pic of how they wired there tecate with out the factory kill switch maybe im doing something wong.im not running my head lights right now either.the hook up is there tapped off.
    Nov 2002
    1,838
    Kill switch should not be the problem. It would not run at all. Mabey its your coil? Brakeing down after it gets hot?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Rawlins350x's Avatar
    Rawlins350x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2007
    Cairnbrook, Pa
    158
    i had to change a stator cover once and had a similar problem. I took the cover back off and found that I didn't have the stator wires properly routed and they were grounding out to the flywheel.
    Just something to check....
    Nov 2006
    southern oregon
    2,338
    fuel petcock?
    2-stroke lover
    kasuki's Avatar
    gasport,NY
    205
    i checked the timming today seems to be good i bought a good cdi the other day so i know thats good.i have a new stator an fly wheel do i need to clean up the frame where the cdi goes for ground or does it ground thru the bolts.i got the trike to run good once got it into 3rd felt like it had good power i try to down shift an died.kick it back over fired right back up .i have tons of time an money in this thing its to the point now where i really might just sell it .
    OK
    5,450
    I know its a long shot.. but is your fuel cap venting? Do you have balck fuel line or clear line from the tank to the carb? Do you have a fuel filter in line? What I am getting at is that when it quits is it running out of fuel momentarily? If you had a clear 1/4" fuel filter, when it quits it would be dry if there was a problem.
    Find someone close to you with a Tecate thats interested in helping swap parts off a running bike. I would.. but I am in Kansas..
    Just a thought.. Good luck.
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
