Thread: 200x Questions?
    Apr 2009
    Sparta, WI
    4
    200x Questions?
    1. Is the 185 motor the same as the 200x motor besides the engine size?
    2. How do you time the 185 motor?
    3. Can you get a wider axle for the 200x?
    I just bought a 200x but it has a 185 motor with pull start. The person I bought it from put a new timing chain on but I think it is timed wrong because it backfires and shoots flames out of the pipe.
    Feb 2009
    michigan
    2,387
    timing
    it is a relatively easy prospect.take off outer cdi cover,2 bolts.then take off inspection plug by pull starter.there are two marks on the flywheel.you will need a flashlight.pull moter over till you see a line with a f and a t.find the t and look at cdi position,should be on the line 12 oclock.if lined up your good.
    1985 ATC 250R
    . Team Red Trike
    Feb 2009
    michigan
    2,387
    timing
    also pull plug its easier
    1985 ATC 250R
    . Team Red Trike
    Jun 2006
    Willow, Alaska
    1,337
    1. The 185 engine is kind of similar, its a pull start, semiautomatic engine. The actual 200x engine has kickstart and a clutch, and a higher compression piston, larger cam, and bigger intake/carb.
    2. Buy a manual, itll make it much easier.
    3. You might be able to find one, but they are rare. Your best bet is wheel spacers, wider hubs from a newer Honda 4 wheeler, or offset rims.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Feb 2009
    michigan
    2,387
    manuals
    plenty of manuals here on the site just search and download
    1985 ATC 250R
    . Team Red Trike
