Results 1 to 15 of 21
Thread: Slowing down a 250R!!!!!!!! Be nice
    Call me whatever you want but I've been on 250SX's for 5 years now - I need chain and sprockets for the 250R and wondered if different sized sprockets help tame this JET down a bit or help in the low end department. No, I haven't rode it but I know it's too fast and I want to work my way up. Everyone says the 85 250R has a lightswitch powerband up in the high revs, I want a chain setup to help out the lower revs and a reccomended silencer for it. Thank you!
    Feb 2003
    Delano, CA
    616
    Put duct tap over the carb.
    1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
    1984 Honda 110 ATC, orignal blue plastics,
    1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
    Honda US90 ATC, Collecting Dust
    2004 TRX450R
    Quote Originally Posted by bigred110
    Put duck tap over the carb.
    How bout on your mouth!! J/K :-D
    Feb 2003
    Delano, CA
    616
    When you get it done take your time getting use to it. Find out how far you need to let the clucth out to find where the clutch grabs.
    Me and my friend took some kid to go riding on his 250ex and he never driven a atv or atc with man. clutch. He was driving my friend 250r in a couple minutes. And the kid was like 15yrs old. He had his quad for about a month when we took him out.
    So just take your time and more times you stall it trying to find the throttle position to get it moving, the better you'll be off.
    2004 TRX450R
    No see the problem is I'm a complete idiot. I'll watch Bubba Stewart and get out there and go BONZAI so I need to tone it down a bit prior to easing up on the clutch or throttle. I had a hopped up 1994 CR250 that absolutely brought tears to my eyes and have ridden for 20 years - I just want to start out with a bit tamer power plant by jettting, silencer and chain and sprocket mods so someone here can help with that Im sure.Thanks
    Maybe a smaller rear sprocket?? DG silencer??
    the best way to tame it down is to keep it stock. stock carb/jetting, stock air filter, stock pipe and silencer. if you change the gearing your just gonna move the power it has around. it will either be fast but require more clutch work to keep it in the meat of the powerband, or it will be powerfull and difficult to keep the front end down.
    Quote Originally Posted by MR ATC
    Hmm, didn't think of it that way - power is power and with lower gearing it'll be standing on end all day.
    MR ATC I have cash - whats left of your inventory for 250R parts. Plastic? silencer? straight pegs? Thank you
    Feb 2003
    Delano, CA
    616
    You can make a restrictor plate, like nascar or put a rev limiter on it.
    2004 TRX450R
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    DIRTCRASHERyou are in control of the amount of power the bike has,,,,,, so maybe toning it down would be best controlled by your wrist and brain,,,,,, if you can't manage to refrain from going to fast i suggest putting an eye patch on one eye !!! when you loose all your depth perseption your mind will automaticlly reduce the size of your testicles!!!!
    that way maybe you won't get hurt or crash as hard!!!!!! its the cheapest way i know to reduce injuries,,,,,,,,,,
    Mike Fort Laud's Avatar
    Mike Fort Laud is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2002
    386
    Let me understand this......You want to slow the bike down....Maybe you just need a slower bike to ride...
    I would rather have a sister in a whorehouse,than a brother with a quad!!!!!!!!!!!!!!!!!!!!!! Still walking the "Tightrope"
    Quote Originally Posted by Mike Fort Laud
    Boneheads need not reply, just want to take my time on it. Have had lots of fast bikes. Not ready for 85MPH
    FullBore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Yeah, Keep it stock, The throttle works both ways you know.
    1979 Suzuki TS100
    1984 ATC70, Broke
    1984 ATC110, Repainted and Rebored.
    1990 Suzuki SJ410
    Unsuspended Antics.
    Jun 2003
    Lake George, New York
    1,732
    Yeah man just keep it stock and dont gas it too much untill u get the hang of it.Your in control of how much power it has. Wanna sell it lol
    Its All Good!!!!!!
    Just thought I'd bring this post back - I always heard how ungodly fast the 250R is even in stock form, and thats why when I knew I was getting one I posted this question. I must admit your all correct - keep it easy on the thumb throttle. I suddenly have no desire to ride any of my 250SX trikes as this THING is just incredible - it's so fast that it's hard to lay off the throttle beacause I've never gone this fast on 3 wheels before. But I do have some self control and have already learned that above everything else keep your weight forwards or kiss it goodbye!! This weekend I'm gonna run the backhoe and take a few feet and the steepness off some of my tracks larger jumps - I already hit my biggest one in just second gear but goosed it and I don't want to do that again. Thank god for the suspension on this thing. I'm gonna have to turn most of these into table tops or doubles. I'm leaving these half bald tires on until I get use to the power but all is well and I'm enjoying the ride with new found enthusiasm!!!
    Apr 2003
    141
    fast
    why dont you just put a restriction on the throttle cable so it wont go as fast then you can adjust it less and less as you get used to it
    Leaks, Leaks, Leaks! Why does it always have to leak!http://www.3wheelerworldforums.com/viewtopic.php?t=11559
