Results 1 to 15 of 15
Thread: My new 250r rearend setup---Update (pics)
    FastZ28's Avatar
    FastZ28 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    Jonestown,PA
    228
    Well I decided to try and get my 85 250r fixed up a little for my maiden voyage to TF and possibly Smith Road. So I had to do something about the rearend, axle is tweaked a little, rotor shot, brake hub and wheel hubs have slop. So I was undecided which route to take on this rearend rebuild and 85 seems to be the odd year out so I ended up going with the 86 style setup. So I called Mike at HRE and had him make me a 86 250r swinger, I ordered a Durablue Eliminator X-33 Pin Drive with Billet Hubs axle, then picked up a billet carrier and a Janssen anti-fade brake hub also some All Balls kits from Dads here on the boards(Thanks Dads). I already had the Proggressive Suspension rear shock spring from when I bought the fork springs.
    I did run into a couple roadblocks already in the disassembly stage. The axle nut, some aftermarket locking type, will not loosen. I tried heating it with a propane torch and yanking on it with a 3ft pipe wrench a few times and it won't budge. So I decided to skip that and removed the chain, brake caliper and master and shock and linkage. Then I went for the swingarm pivot bolt, no go. I got it to turn and got the nut off but the bolt is stuck. I heated it with the propane torch and hit on the nut with the sledge and it didn't move. So I am gonna go get some Mapp gas and try heating with that and hit on it some more. If that fails might have to cut it out.
    After I got the shock out I noticed it was stamped on the top "1989" so I am gonna guess its a 1989 trx shock and linkage that someone possibly swapped in before I got it. I am dropping my shock and the spring off later today to get rebuilt. Hopefully they can tell me if it is a 1989 shock or not when I take it in. So here are some pics of my new goodies
    Attached Thumbnails Attached Thumbnails Parts1.jpg   Swingarm.jpg   Carrier-brakehub.jpg   Axle-spring.jpg
    84 Z28 Camaro
    94 Caprice 9C1
    02 2500HD Silverado 4x4 ext cab
    84 atc70
    85 250R
    87 Big Red
    90 VTR 250
    Baltimore, MD
    6,088
    Very nice. They do great work at HRE don't they? It should look really nice when finished. Keep us posted on the progress.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Ontario, CANADA
    4,538
    If you dont mind me askin, what did that HRE swinget set ya back?
    Lookin great man! I want to see pics of the whole deal
    btw, come race with us. You will have a BLAST!
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Nov 2005
    New Jersey
    659
    yes-could you list what the items ran you if you don't mind-I am in need of a new swinger myself for my 86 currently-
    http://www.pilotodyssey.com/PO/index.php
    88 TRX LRD,39MM pwk,Durablue+4.Nice rider
    85 250r West Coast +4,Durablue +4,Boyesen rad valve,Keihin 39mm,Rad double row carrier
    86 250R west coast +4,Durablue+4,Maier plasitcs, Keihin, Boyesen,Wiseco big bore kit
    85 350x-all new everthing,trailer queen,all OEM-NOT FOR SALE!!
    4-FL400R HONDA PILOTS.See my section on the page!
    2-85 T-3 Tecates all the bells and whistles
    85 T-3 project trike in works
    FastZ28's Avatar
    Oct 2006
    Jonestown,PA
    228
    If you dont mind me askin, what did that HRE swinger set ya back?
    The swingarm cost me $475. It is stock length with skidplate mounts and uses the stock front chain slider. Let me just say it is a work of art!!! The welds are flipping beautiful !!!
    Durablue axle $499 (Rocky Mountain w/ promo spend $500 get $100 off, so it cost more like $399)
    Carrier $120 (Ebay)
    Janssen antifade $149 (Ebay)
    New pivot bolt&nut $39.44 (Ebay)
    Braking rear rotor $75 (Ebay)
    07 YZ450F front caliper $45 (Ebay used, gonna use for rear caliper)
    All Balls swingarm bearings $55 (Dads)
    Lonestar Brake stay kit $55.79 (Dennis Kirk)
    I can't think of anything else at the moment.
    I might be taking my footpegs to HRE and have him fab up some wide ones with kick-ups. If I do I'll let you guys know that have 85 250r's.
    84 Z28 Camaro
    94 Caprice 9C1
    84 atc70
    85 250R
    87 Big Red
    90 VTR 250
    Rawlins350x's Avatar
    Rawlins350x is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2007
    Cairnbrook, Pa
    158
    I wish I had money for shiny parts
    CUYAHOGA FALLS, OHIO
    1,242
    Those rear progressive springs make a huge difference. That shock will feel like a 800 dollar Elka!!! Nice stuff there bud.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    ^^^ Ditto that. I loved mine when I had it. Damn stock shock rode like a caddy and still took larger bumps/jumps with ease.
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
    Sep 2008
    Northwest Indiana
    550
    Swinger looks great....Mike did my 85 Tecate swinger! Very clean welds...
    1985 KXT250 A.K.A. "Doom"/Multiple Engine Combinations/Jason Hall Inverts/HRE Swing Arm, Cal Fab Swing Arm/Jemco Pipe/Buzz Saw Cylinder, Klemm Research Cyinder/PWK Carb/PVL Ignition/Dura Blue Axle/Mosh Custom Seat
    Oregon
    2,471
    Question
    how much was the Proggressive Suspension rear shock spring ? ? ?
    Please don't forget to Write a Ride report !
    Sep 2003
    Elizabethtown PA
    1,581
    i seen you mite be heading out to Smith Rd. maybe we could take my truck and trailer out and save some coin on gas. I plan on racing my trx250r out there and maybe my 85 atc250r if it is working.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    FastZ28's Avatar
    Oct 2006
    Jonestown,PA
    228
    I bought it a year ago off ebay for $60.
    Yeah if I get this finished in time and test it out I would like to go. I'll get back to you when I get a little closer to being finished.
    Place I took the shock to said one and a half to two weeks till its done. Plus I still need to get the pivot bolt out and rebuild my front caliper I have torn apart. My buddy gave me some galfer brake lines off his 03 CR250 and they are almost a perfect fit on the 250r. I will post pics of them when its back together. I still need to decide if I should buy new reeds for the rad valve thats on it or buy new VF3 setup. I was lookin at the pro series reeds and they are half the price of a VF3, so I was thinkin might aswell go the rest of the way and get the VF3, I dunno.
    84 Z28 Camaro
    94 Caprice 9C1
    84 atc70
    85 250R
    87 Big Red
    90 VTR 250
    FastZ28's Avatar
    Oct 2006
    Jonestown,PA
    228
    Just a quick update got the swinger bolt out yesterday. I heated the rear motor mount where the pivot bolt goes thru with mapp gas and gave it some whacks with the sledge and it finally moved. Then my dad got out the air /chisel with a blunt end and it pushed it out. The lower linkage bolt was stuck too and the air pushed it right out.
    84 Z28 Camaro
    94 Caprice 9C1
    84 atc70
    85 250R
    87 Big Red
    90 VTR 250
    Feb 2009
    michigan
    2,387
    85 250r
    nice f---en project.should look sweet when together.hope to see it at TF.make sure to put up a finish pic
    1985 ATC 250R
    . Team Red Trike
    FastZ28's Avatar
    Oct 2006
    Jonestown,PA
    228
    My new 250r rearend setup --- Update
    Well its together, no pics of it finished but some from the other night.
    I put on a crf rear master but I don't know if its gonna stay. I can't get it to pump up tight it just seems real spongy. Maybe its too small for the yfz front caliper I put on the back or something. But heres some of the progress.
    1st is the crf rear master I put on.
    2nd clearence between it and swinger
    3rd backside view
    4th brake stay modded for yfz front caliper
    5th IMS pegs
    6th Linkage and shock back on.
    Attached Thumbnails Attached Thumbnails DSC00815.JPG   DSC00819.JPG   DSC00820.JPG   DSC00824.JPG   DSC00817.JPG   DSC00823.JPG
    84 Z28 Camaro
    94 Caprice 9C1
    84 atc70
    85 250R
    87 Big Red
    90 VTR 250
