Fewwww!!!!!!
wow!! i rebuilt my motor and i broke it in correctly and it sounded great tons of power and so on. I took the valve cover off , retorqued the head bolts , and put the valve cover back on and redid the valve clearance . Well i turned it on today and i was like man that is loud in the head today so i turned it off. Checked the timing chain tensioner and it is still working. So i took the valve cover back off , and i checked the chain and the friggin bolts that hold the sprocket to the cam backed out some and it was loose. I am soo glad i took it off now , i almost
when i saw that. I knew it didn't sound right. I think what caused it was i forgot to put the top engine brace with the 3 bolts and nuts and it made the top vibrate and they backed out some. I rechecked my timing , but a little lock tight on the threads and installed , i let the locktight dry , and reinstalled the valve cover. INSTALLED the top engine mounts , bolts and nuts , and redid valve clearance . Turned it on and the noise is gone!
just wanted to vent / breathe a sigh of relief
anyone else have a brain fart that could of been horrible but you ended up catching it in time ?
1985 ATC 250ES Big Red
1985 ATC 350x DG Exhaust , Wiseco 10.25:1 .20 over - Sold
1985 ATC 200s - SOLD
