will a 350x engine fit into one of these bad boys. i might have located my next project.
My brother did this several years ago.
http://www.3wheeler.org/vb/showthread.php?t=4087
Survivor TF05, TF06, & TF07
Survivor BF05 & BF06
1985 350X
2000 Banshee
1992 Indy Sport - SOLD!!!
350XRiders Online Merchandise
ATC 350X Online Merchandise
TRI-Z Online Merchandise
i have built several and have posted on here about some of them
you only have to change 1 mount in the frame...if you choise to cut the motor to fit the frame you might run into a torn off mount like what happened to me.
do it the right way and change the frame and not the motor.
WWW.HREATV.COM
Does Any one know which disk brake front end will fit on a 86 250 bigred as i am getting tired of replacing the brake shoes and drum every year since i can never get the drum off without cracking it i know they make em but cant figure what one will fit so anyone done this???? and will i have to replace the rim??
Not sure about a brake swap, but post this question in trikesylvania and you'll get some help.
Tionesta Trikes ATC 450R
86 250R
86 Tecate-3
83 ATC 70
85 Big Red
81 KLT 200
85 250SX
just the back mount is different its easy to change though. powroll has a kit and a pipe. you cant use the stock 350x pipe... i built one for mine.
