does anyone have a paint code for the white on a 86 250sx tank? i was also thinking of powdercoating which would be better.
I use champion white its a GM color
The White code I use is... mae 838 I have it mixxed up and put into a can. It is a little more expensive but it looks PERFECT. Put the decals on and have it clear coated at a body shop.. I cut about a 1/4 of the white off the edge of the tank fill so the gas won't penetrate under the paint. Clearcoat for some reason won't alow this to happen. If you don't cut the paint off in about 6 months the paint will bubble all the way around the gas cap and then you can start over.![]()
I have just started to powder coat stuff and have not found a match yet. You will find the "White" has some red and Yellow in it and has more of a cream color to it when you look real close. I do know the 85 to 86 white is differant though.
Good Luck and post pics when your done.
1978 Honda 90 / 1979 Honda 110 / 1983 Honda 110 Racer (in the Works)
1973 Honda 70 / 1983 Honda 70 / 1983 Honda X-mas special / 1984 Honda 70 / 1985 Honda 70
1985 Honda 200X Stock Original![]()
1985 Honda 350X![]()
1985 Honda 250R![]()
1986 Honda 350X
1987 Honda 250SX
