well after some dicking around trying to find the drive sprocket for this, i got her fired up! I changed the oil, and flushed the tank, new fuel filter, and plug. tried to start it, but it wasnt getting fuel through the carb, so i pulled it, tore it apart, it was a mess, put it back in , and after a few adjustments, she seems to be running pretty good. I got a 10 tooth sprocket, but should have got a 9 because the chain is EXTREMELY tight. so i only rode it a bit, but it seems like fun. gas cap seemed to leak a bit. lots of vibration at full throttle. brakes work awsome. I got a 9 tooth on the way, and i also have some extra chain and masters, so either way ill get it straightened out. I will post back with a better ride report. I also have some good info on these in pdf that I was able to dig up if anyone is interestd.
