Thread: 200x shock rebuild
    adamd's Avatar
    adamd is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    west ky lbl
    269
    200x shock rebuild
    are the 200x back shock rebuildable if so what seals are needed i posibly have the ability to fill them back with nitrogen if not ill just be finding a new shock
    3 wheelers
    1983 200x flat tracker
    1983 200x almost original
    1983 200e bigred parting out
    let me know what parts you need
    Southern MN
    1,875
    I guess they are rebuildable. The main seal you will need is the one on the shaft located under the cap. There are also o rings inside the shock that go on the shaft head. You have to pull the whole thing apart and you will see. Im not really sure where to get the shaft seal. I would check bikebandit.com Youcan probably match up the o rings at the local hardware store if you are good. Good Luck.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Mar 2005
    ma
    988
    yes they are rebuildable. if there in good condition. if the shaft is rusty its junk.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    adamd's Avatar
    west ky lbl
    269
    the shafts in good condition looks new just has no presure it set in a garage for 20ish years so i figure the o rings finaly just gave out
    3 wheelers
