ran fine when bought a week ago,,ticking in topend tho, hoping just valve clearance,,but started just a touch of elec, start, and ran excellent,
cleaned air box out,,wasnt too bad, few bees and couple other insects in bottom,,did not clean filter tho, cause can't seem to get foam from around the filter, off the filter, must be aftermarket, and discard only or something,, cleaned the breather tube out and the bowl under the fuel petcock,(both of which were jammed full of junk) changed the oil (not filter tho) used 10w-30,,
went to start it, started fine,, but bog at 0 - 1/4 throttle,,then died,, took alot to start it again, tried choke, gas cap off, air box cover off, and finally started again but bog again,, took for a little drive and after enough screwing with gas cap and choke, started to run right again,,then started it again, in 5th mostly, but sometimes when just puttering around too,, then trouble starting again, took plug out,, tip is black, porcellein is brown, threads have black ring around the tip, dry,
it seems to do this kinda when ever it wants or feels like it, i am gonna try and take fuel filter screen thing out out of gas tank and clean, if not rusted on too bad. also take off carb and clean, (do i HAVE to have new gaskets for carb), maybe see if can get a new air filter, new plug, adjust valves,
do you guys think this is fuel problem or air problem? would the valves needing adustment cause this?,, manual says 10w-40, would using 10w-30 make a difference? just weird cause trike ran great, before i cleaned out all the junk? I know i just need to do what i said im going to do,, but just wanna know if anything else i should check while going through trike, cause i don't have a shop here, and have to travel a ways to use one,
thanks for any suggestions you guys could give me, and sorry for the long winded post, just a noob and gotta learn how to explain better and shorter,,![]()
, so i drilled a hole in the top of the gas cap and put a hose on the end to keep junk out, dont bother trying to get a new one they cost like $50+ and they work better with the hose anyways.
