Results 1 to 9 of 9
Thread: Yamaha YTM 175 Timing Chain how hard is it
    Holland, NY
    635
    I had a guy ofer me a ytm 175 trike for a really good price...he said it raan till the timing chain broke...How hard is it to reaplace a timing chain?
    TRIKES:
    1985 Yamaha YTM 225 DR Special Edition
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    2001 Ski Doo MXZ 600
    1997 Ski Doo MXZ 583
    Nov 2002
    Kirkville, NY
    3,831
    Well,,,,,,
    The YT 175 is 2 stroke (no timing chain).
    The YTM 200 is 4 stroke and has a timing chain. it is not too bad to do, you can take the pull starter off, stator, flywheel, and engine cover off. Then take the cam cover and sprocket off and pull the new chain up through the top end.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Holland, NY
    635
    so there is no timing chain? Do you think the guy ment the drive chain or what?
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    Baltimore, MD
    6,088
    Maybe you should go look at the trike. If it is a drive chain, you have to remove some parts, but it's not too hateful. If it is a ytm200 and it is a timing chain issue, it will be alot more involved. Not impossible, just way more involved. You would need a service manual and a decent set of metric tools at the bare minimum. Also some prior mechanical experience would be a big help. It's not that easy of a job for someone without a fair amount of wrench turning experience.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Holland, NY
    635
    He said it was a Yamaha YT175 if its a 200 i dont want it i want something different than my 225 like a "racer" type trike...Drive chain will be eay....But for $75 i might buy it just for the heck of it
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    Nov 2002
    Kirkville, NY
    3,831
    A YT175 is 2 stroke but I would not say it is a "racer" type.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Holland, NY
    635
    How fast are YT175's? How many gears do they have?
    TRIKES:
    Dirt Bikes:
    2006 Honda CRF 250R
    SLEDS:
    Yamatrike400's Avatar
    Yamatrike400 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    MINNESOTA
    393
    Yeah the 175 is more of a sport trike, but i've always wanted one to mod into a racer. Since its a 2 stroke its easy to modify the hell out of it. Port it out, raise compression, bigger carb, better expansion pipe...etc
    Three Air R's
    Southern MN
    1,875
    They are a 5 speed with the auto clutch, just like your 225 dx. The 175 may have faster acceleration than the DX, but the DX will likely get it in the long run. The DX has much better suspension up front, and the 175 does not have any rear suspension from the factory. Top speed for a stock 175 is right aroung 55 or os................
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
