Results 1 to 12 of 12
Thread: 185S Atc
    79fordblake's Avatar
    79fordblake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2009
    Wingo, Ky
    278
    185S Atc
    I just got a 1981 185S three wheeler that my uncle gave me. Runs fairly well and doesn't smoke. Plastic is in good condition. It just needs alot of little things done to it.
    Right now my problem is it is very hard to start after it sets over night and when its reved up it takes a while to return to idle. Sometimes it high idles by itself until I put it in gear. I read the post "Carb Jetting 101" but I don't have any idea where any of the adjusting screws are located. Can somebody post pics? What brand oil do you recommend I need to change it. 10W40 right? Thanks in advance.
    May 2008
    Blackstock, Ontario, Canada
    89
    Quote Originally Posted by 79fordblake View Post
    I'm not exactly sure about the high-revving, it may be carb related. Something as simple as a stiff cable or throttle slide. Good idea to clean the carburetor.
    About carb adjusting, the idle screw is on one of the sides of the carb, not sure which one. The pilot screw will probably be on the bottom of the carb, by the bowl, facing downwards. Lastly, I believe all the other jets, etc. will be inside of the float bowl. I am not familiar with the 185, so I can not confirm any of this. Just trying to help.
    Feb 2009
    michigan
    2,387
    185s
    your idle screw is on the right side of carb,and the mix screw is bottom front of carb.factory settings are 2 tuns out each.run them in and back out,dont over screw them in.the high reving could be the anti surge cup in the bowl,plastic cup looking
    1985 ATC 250R
    . Team Red Trike
    Monroe MI
    5,787
    Welcome to the board.
    rdlsz24 had a manual for that, hopefully it's still available. 185s is covered at the end.
    http://www.mediafire.com/file/dmijww...nes_Manual.pdf
    Read this post by DC, it might help.
    http://www.3wheelerworldforums.com/s...ad.php?t=23819
    May 2009
    Wingo, Ky
    278
    Thanks for the help everybody. If there is something wrong with the anti-surge cup is that something that would be in a rebuild kit?
    Feb 2009
    Rome,NY
    1,046
    its probably just dirty take it all apart jets and all and clean really well
    Feb 2009
    michigan
    2,387
    i havent seen it in a rebuild kit.it usually falls off during reassembly and sits in the bowl or not put back in at all.try a good cleaning though that is the usual suspect.clean all the little holes in the carb and carb parts
    1985 ATC 250R
    . Team Red Trike
    May 2009
    Wingo, Ky
    278
    I havent cleaned the carb yet but I noticed the bottom of the slide is kinda rough from something. Can I smooth this over with a fine file and sandpaper or do I need another one?
    I adjusted the timing chain, valves, and clutch today. Engine is much quieter now its been needing routine maintence done on it for a while. Also changed the oil. What should I do to lubricate the drive chain? I adjusted it as well.
    1981 Honda 185s
    DG Exhaust, Clamp on Uni Air Filter
    '85 200x carb, 200 Cylinder (SOLD)
    1981 Honda 185s
    Straight Pipe, Uni Air Filter
    200x Carb, 200 cylinder (SOLD)
    1985 Honda 250ES Big Red
    Uni Air Filter
    1986 Honda 250ES Big Red
    Uni Air Filter
    Sep 2007
    100mi west of Chicago
    3,582
    Yeah you can smooth out the slide no problem. For drive chains I always use chain lube that you can get at the dealer. Or you can always use white lithium as well. I think the owners manuals say to use motor oil or gear oil.
    Rob
    May 2009
    Wingo, Ky
    278
    Where would I go to find things like the rubber gromments that go under the rear fender and behind and down the side of the fuel tank? Mine are almost gone.
    1981 Honda 185s
    1981 Honda 185s
    Uni Air Filter
    Uni Air Filter
    Sep 2007
    3,582
    You can find decent used ones on eBay or go to the dealer for new ones. They can still get those I believe.
    Rob
    tbirdscott's Avatar
    tbirdscott is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    Prince George B.C.
    216
    Had a hard start and slow idle return problem with my 185s, ended up being a broken timing advance lever. Remove the cap on the left side of the head and hose it out with brake clean then spray it with penetrating oil. turn the center piece with your fingers and you should see both advance arms move in and out.
    Scott
