Results 1 to 15 of 54
Thread: ATC no run
    May 2009
    Brampton, ontario
    686
    ATC no run
    Hey everyone, i have a 1983 honda ATC 185. i have compression spark and fuel, and i have the 0 on the cam gear lined up with the magnito under the cdi cap and the line on the flywheel, pulled the cord 20 times, put fuel right into the cylinder tried quick start nothing, any 1 have any ideas?
    Brad200X's Avatar
    Brad200X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Will County, IL
    357
    Welcome to the boards Luke. Sounds like your intake or exhaust pipe could be clogged. I would check the airbox and header/muffler and see if anything crawled in their and made a home. I would double check the fuel, spark and timing first though. That's the only thing I can think of right now...
    Rides I own:
    '85 200X(old smokey)
    '81 ATC250R(Bassani pipe, Wiseco piston, Vesrah rod, and AMS offset rims)
    '84 KXT250 Red(the new money pit!)
    '96 KX125(FMF pipe, Boyesen reeds, One Industries graphic kit, etc.)
    '85 KX125(vintage racer. Technically it was a practice bike)
    '78 DT400(the lone Yamaha)
    Baltimore, MD
    6,088
    Fuel, Spark and Air are what make up the fire triangle. You say you have fuel and spark. That means I would seriously check into your air intake system to look for something not allowing air into the carb. Low compression will make the engine run really bad, but compression won't keep an engine from at least making an effort to start. You should at least have popping or back firing or something along those lines. You may want to make sure you haven't sheared a key in the top of the head or something that would keep the valves from opening or closing up or keep the cdi mechanism from turning. Best of luck with this and keep us posted as to what you find.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    May 2009
    Brampton, ontario
    686
    no run
    Thanks for the posts guys, i have the airbox off, rebuilt carb, no keys are missing valves open and close nicely. it is timed.. 100%, i get some air from the muffler when cranking it over. the only thing i can think of is a weak stator, i thought if it was weak i would get weak spark. but i get prime spark, but some 1 told me it still could be the stator and the pull cord isint enough turn to get it running, i should try push starting it. some one also told me if i had a bend or non seated valve it would not run, but if i had a bad valve i would lose compression though right?. i have great compression.
    Dec 2002
    deer park, texas
    2,336
    yes you would lose compression, if you have a strong spark it isnt the stator
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    May 2009
    Brampton, ontario
    686
    well im completely frusterated at this point. i have no idea what i could be, ive checked the timing 100 different ways people have told me to check it. its dead on.. i have a professionaly rebuilt carb, fresh gas. and a prime blue spark. you can sometimes hear it its so good. the only thing i could think of is not getting spark on the combustion stroke.. but you can only have that off by half a rotation if your timing is right. and ive tried both positions for the CDI magnito and no start for either.
    outtaline is offline My keyboard has no punctuation keys Arm chair racerJust too addicted
    Feb 2009
    531
    is the plug getting wet?
    May 2009
    Brampton, ontario
    686
    it does get a little bit. but now that i think about it. not nearly as much as it should be for how much ive pulled the cord. what could this be with a fresh carb?
    Feb 2009
    531
    what does it do if you spray starter fluid in the carb then pull it and not carb cleaner real starter fluid
    May 2009
    Brampton, ontario
    686
    like quick start? i tried sparying that into the carb didint work.
    Feb 2009
    531
    then its not fuel funny one what does your oil smell like? gas?
    May 2009
    Brampton, ontario
    686
    smells like oil, but its not the nicest looking oil around. i really should change it. but i wanted it to run before doing that.
    Feb 2009
    531
    how much compresion does it have
    Feb 2009
    michigan
    2,387
    carb
    make sure the carb was set to the correct settings.idle screw out 2 turns and mixture 2 turns out.the idle is on the right side of the carb and the mix is on the bottom of the carb.
    1985 ATC 250R
    . Team Red Trike
    Feb 2009
    531
    that wouldn't even matter if it doesn't even pop with starter fluid
