Results 1 to 15 of 17
Thread: HAHAHAHA 122.7 mph Tri-z
    OK
    5,450
    http://wichita.craigslist.org/mcy/1197136893.html
    " it just blew a hole in the piston the walls are fine so all you need is a .40 big bore piston and rings and install it i was clocked at 122.7mph when it blew the hole and i was only half way through 5th gear so its craaazy fast with all the mods and big bore kit"
    ha ha ha classic...
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Jun 2003
    englishtown NJ
    2,676
    a hole in the piston is a clear sign of detonation, not enough oil would seize the top end. Let me guess, the 40 over piston is the big bore kit, its still probably not a 250cc or just barely over. 122 mph, thats too much, Ever ride a dirtbike 80 mph in the dirt, I have. And its SCARY, add 40 mph to it, I don't see happening.
    Jan 2004
    Palmetto,Florida
    2,300
    The ONLY 3-wheeler that will go OVER 100 MPH is from Fla.
    from looking at THAT Pic of THAT Yellow THING .... NO WAY it will do over 68 mph
    "07" DR650 Suzuki Dual Sport
    louisiana
    1,499
    100+
    Quote Originally Posted by Yamahondaman View Post
    any pics of the one that does over 100
    Signature pic removed,becuase of no helmet.
    Brad200X's Avatar
    Brad200X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Will County, IL
    357
    LOL! That's too funny. What kinda mods is he talking about, a flux capacitor!? The only three wheeler that I've heard to go 100MPH+ is Tracey Dickson's Husqvarna. Anybody who says otherwise is simply exaggerating.
    Rides I own:
    '85 200X(old smokey)
    '81 ATC250R(Bassani pipe, Wiseco piston, Vesrah rod, and AMS offset rims)
    '84 KXT250 Red(the new money pit!)
    '96 KX125(FMF pipe, Boyesen reeds, One Industries graphic kit, etc.)
    '85 KX125(vintage racer. Technically it was a practice bike)
    '78 DT400(the lone Yamaha)
    OK
    5,450
    I'm not going to lie.. I have a fast Tecate. It might do 70 mph.. but I KNOW.. It will eat that Tri-Z
    Rides:
    My feedback thread
    Feb 2008
    NE Indiana
    525
    "I let my buddy mix the gas and oil."
    Who's dumb enough to do that? Oh yeah, that guy.
    smvorndran
    Hampton, Virginia, C.S.A.
    2,664
    hehe it does 0.0 mph with that hole in the piston
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Mr.Atc's Avatar
    Mr.Atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    gulliver,mi
    248
    the tri z was known to not hold up
    MA
    384
    Dunno if I'm 100% on my info, but having fun none-the-less.
    ME:
    Lol if by 122MPH you mean 70, then I believe you. There's only one three wheeler in the country that I've heard of going over 100, and that was a trike in Florida.
    You have a stock trike with a .040 over piston which adds no extra power... stock bikes do around 70.
    HIM:
    kool thanks for the info! I thought that more horse power ment faster and thats crazy i wonder why people buy exhaust and reeds and big bore kits if it goes the same speed and all man people are dumb. Im glad you emailed me from now on ill save my money and just build stock bikes since add ons wont make it faster. You know im wondering how that guy made his drag bike go faster OH he must of had like an 1100cc STOCK motor in it LOL!
    ME:
    Reeds don't make you faster, they simply compliment the other mods (if you had any) to get the proper air/fuel. http://www.geocities.com/redrd400/rd/reeds.html
    You don't have a big bore kit. Big bore kits come with a larger cylinder and raise your cc's. You are simply overbored, and that doesn't increase the cc's.
    You have a stock bike. Stock Tri-Z's go 70MPH. Whoever clocked you was either a moron, had improperly calibrated equipment, or it never really happened.
    OK
    5,450
    Tri-Zowned...
    Rides:
    My feedback thread
    Apr 2008
    Kalamazoo, Michigan
    814
    lol i had a buddy that told me his predator did 120 mph, because he had a buddy race him down the road in his el camino..
    The only way this is possible is Tall gear up front and a small gear in the back and MAYBE? although you would need some space to stretch its legs.
    but if it truly runs with a piston, i say someone go get a .40 over piston and go check it out $800 bucks ain't bad imo
    springville, PA
    6,185
    Should have told him that 40hp with 13/42 gearing will have the same top speed as 100hp with 13/42 gearing, but you'll wheelie all the way to your 70mph barrier
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Oct 2007
    Grosse Tete, LA
    3,440
    Quote Originally Posted by aaron7 View Post
    http://www.nightrider.com/biketech/c...splacement.htm
    255cc rather than 247cc or so which is stock...it's only a 1 mm overbore. doesn't increase much on when you only have a 68mm bore to begin with.
    however...
    take the 350x for example
    stock stroke of 68mm....stock bore of 81mm
    when you bump it up to an 83mm...you also bump it up to 270cc. not a bad gain considering.
    Raising your max rpm will ALWAYS raise your top speed...all other things constant, doing mods which will raise your peak rpm will raise your top speed.
    Having said that...he DID not break 100...with stock gearing I'd also be willing to bet he did not break 85.
    There ARE exceptions to some rules...
    For example, schmee's rebuilt 83 300r with stock gearing...on 20 inch tires (geared lower than stock) with his sectional pipe, portwork, and larger carb has been clocked by ME at 75+ mph on multiple occasions. I've seen it at 77... and that's with a slight bend to the axle. I think with a perfectly straight axle, the bike can touch 80, the wobble inhibits the tire from expanding. Those speeds were clocked with my car...AND gps, they are accurate.
    Sep 2005
    MICHIGAN
    2,027
    I always like to say "122 MPH? Yeah, off a cliff with a tailwind".
    There was some kid with ludicrous 100+ MPH claims on craigslist when selling a 1985 LT250R. And he did not give a sheet what I said about his fantasy ad.
    Of course the quad was so fast it blew up too. Always love to point out the fact it runs at 0.0mph now.
    But don't you wonder how many people buy into this alternate reality?
    86 T3
    84 T3
    86 KX250
