Results 1 to 15 of 48
Thread: Cagiva - First Impression / Ride Report ==PICS ADDED Dial Up Beware
    Dec 2002
    deer park, texas
    2,336
    The cagiva showed up last night. Cosmetically it is trashed. This morning i pulled it out and started eye balling the unsual stuff on it. Pulled of the rear plastics seat and averything looked to be origial. started to pull the carb off and i noticed the boot had been torn and repaired with fiberglass. The 36mm Delorto was in good shape but a little gummed. the crab is positioned between the shock and pipe. It is a pita to get to. I then checked the coolant. It was full and green. i then checked the trans oil. It wasnt registering. Added some and it poured straight out the bottom. Flipped it over and there was a dime size hole in the bottom of the case. I grabbed my putty and did a quick fix. I then pulled out the drain plug and there was tons of metal shaving and a couple of clips. the bottom end was grenaded. I thought what the hell, filled it with oil. Put gas it in and it finally cranked after about 50 kicks.
    This is a very intimidating machine. It vibrates and has the meanest throatiest sound i have ever heard. I wanted to take it for a ride but it doesnt have brakes and the intimidating sound had me nervous. finally convinced my self to go for it. This is a very light machine and is geared relatively high. I never got a chance to get it out of second gear. the power was crisp and with the long rake the front end was easy to keep down. It was a diffrent ride from what i am use to. I know i will need to split the cases, but that will come later. The ergonomics of this wheeler suck. The kickstart is built purposly to break your shin. The shifter is very close to the engine. with boots it would be imposible to shift i thing. Rear brake pedal is the same way. alright, back out to the garage.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    NY
    3,185
    Sweeeet !!!! Dont pull that motor apart whatever you do!!
    Dec 2002
    deer park, texas
    2,336
    I know, i am kinda stuck. It seems to be working fine but i know it is tore up in there. I hate to run it and make it worse, but dont want to pull it apart and try to find parts. i havea long road before i get there anyway. Fixen to pull the mugen build off of the operating table and put the cagiva on there.
    OK
    5,450
    Pics please....
    Rides:
    1982 ATC70 (Lifan manual 125)
    1987 LT80 (piped, widened)
    My feedback thread
    RIP Trace.. Godspeed.
    Dec 2002
    deer park, texas
    2,336
    Pics please....
    we went to a graduation this weekend and lost the camera. i have been trying to find the video camera charger to i can take a vid.
    Baltimore, MD
    6,088
    Barry, be careful running that cagiva. I had my Tiger 250 running before Bruce and I tore it down, and it ran with a wrong crank in it. Tony in CA said he was amazed that it would run with the wrong crank in it, but it did. And it sounded pretty mean too. Try to not do any more damage than there may already be. I know the temptation is great, especially once you hear it run that first time. That is what is great about the Tigers though. They are so simple and the parts are still available for the most part. I can't imagine what a pain that cagiva is going to be. But I saw that ad after you did and I would have had to buy it. I know it is in good hands though. But you may just want to split those cases to take a look. I'll be keeping a big eye on this build. Best of luck with this trike.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Feb 2009
    michigan
    2,387
    dang dude, it seems that the stars are not in line for this build.take your time and do it right those holes in the cases will have to be addressed.good luck,and oh yea show us the pics.
    1985 ATC 250R
    . Team Red Trike
    outtaline is offline My keyboard has no punctuation keys Arm chair racerJust too addicted
    Feb 2009
    531
    put it back in your pants harry and give him some room to breath its like a new baby in the house he needs some room to think lmfao
    Feb 2009
    michigan
    2,387
    cagiva
    i know, but i get exited about cagiva's.just cool trikes
    1985 ATC 250R
    . Team Red Trike
    Feb 2005
    Orchard Colorado
    659
    WAIT!!!!!!!!
    Quote Originally Posted by Orangecnty250r View Post
    I'd listen to OC when he say not to slipt the cases... Until you've found the gaskets and seals. Bill, I'll scan the manual and get you a copy.... I forgot
    Instead of jumping into it, it's not going to get any worse sitting there, start looking for the parts you'll need. Your starting out on a long road and it'll take you a while just to get the parts needed, then start your rebuild.
    '85 Cagiva 200
    '86 Cagiva 500
    '82 ATC 480R
    '83 ATC 250R DG
    '83 Nicholson 185s
    Owned 5 Franks, sold 4, have one left.
    Dec 2002
    deer park, texas
    2,336
    It got put up on the operating table last night after i sold the 250r. It will not be ran anymore. i just couldnt resist blazing up and down the road a few times. engine will be yanked and put on the shelf. I have alot of powdercoating and rebuilding to do elsewhere, then just keep my eyes open for parts or maybe get lucky and find a nice bike somewhere to pull from. i will keep everyone posted and i will put up pics with the camera gets found, or we buy another.
    Baltimore, MD
    6,088
    I only suggested to split the cases so he could make sure that he wasn't doing any damage by running the trike. He can reassemble the cases using any number of fine products like yamabond to put the cases back together until he can get the parts to do it right. I know how hard it is to get cagiva parts and I also know how hard it is to fight the temptation of running your newest bestest toy. Plenty of people have taken engines apart and put them back together and not used new and fresh gaskets and seals. I'm sure he will do a proper rebuild of the bike as soon as he has the correct parts and is able to do so. It just would have been a very sad day to see him run his cagiva and something internal lock up that he didn't know about without looking.
    Nicholson 185s
    PA
    3,515
    alot of 2 strokes use no center case gasket anyway...i'd open it up too
    WWW.HREATV.COM
    louisiana
    1,499
    barry here's some parts you may be able to use http://pittsburgh.craigslist.org/mcy/932568172.html
    Signature pic removed,becuase of no helmet.
    Sep 2008
    Maine
    70
    I can't wait for some pictures/videos. Sounds like it will be a good restore once finished!
