I broke off a exhaust stud with about 1/4 inch or better sticking out. I'll be damned if i can get it out so I have to put a new head on it. I have some questions though.
The manual I downloaded for the 200ES doesn't have proper disassembly instructions for removing the engine. What is the easiest way to do this? Can the sub transmission (hi/lo/reverse) be removed in one piece without messing with the gears inside? If i remove the rear end and the rubber boot for the drive shaft will it simply slide out? Does anyone have any tips for me?
